Discuss
CAN i DO THIS
 in
My wife lifted the non-removable top of our maytag. The gas pipes leading to the 2 front burners snapped.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » CAN i DO THIS
  #1 (permalink)
Old 03-24-2008, 05:18 PM
dawgtired dawgtired is offline
Junior Member
dawgtired is on a distinguished road
Default CAN i DO THIS
Model Number: mgr5710adw   Brand: Maytag   Age: 5 - 10 years
I have fixed just about every other appliance and gas and/electrical thing we own from the hvac to the outdoor grill to the jacussi.
I have identified the part(s) I need as the Fitting assy., Orifice (lt) Part Number: AP375397.
I think I can do this. Can I do this?
Any advise? There is less available on line than other diy repairs I have made.
Thx
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-25-2008, 12:55 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
This part is not too difficult to replace yourself and I believe you can do it.
The part number you mentioned is for conversion to LP. You have to order the fitting assembly with the part number AP375375. Looks like you'll need two of them.
Here are the break down diagrams for the Maytag range Model MGR5710ADW
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-25-2008, 02:20 PM
Junior Member
Default
Thanks Gene.
I have noodled out the r and r. It looks stright forward. Thanks for the heads up on the part correction. Yes I need 2. There is no "right hand" I presume. I will order them as soon as you confirm the same part fits both sides.
cheers!
  #4 (permalink)
Old 03-25-2008, 03:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
There is no "right hand" fitting assembly in the parts list.
If the burner knobs on the control panel are (from left to right) left front, left rear, right front and right rear - then both parts are identical.
__________________
  #5 (permalink)
Old 03-25-2008, 05:12 PM
Junior Member
Unhappy
Dang it! In fact It is set up L-front, L-rear, R-rear R-front respectively.
I will need to call and check into the availability of a "right side".
Thanks again for the heads up.
I'd like to order from this sight given the prices and help I rcvd.
  #6 (permalink)
Old 03-25-2008, 05:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Call the APP customer service (877-477-7278) and ask for Adam.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
