The left front infinite switch (AppliancePartsPro replacement) AP4291911 of my Jennaire cooktop broke from the its holder. I bought the above and rewired it the same as the right side.
Now the switch only goes on at high. And, the rear left, when turned on, turns the front replaced switch on to high also.
Is there a short in the switch? Do you have a schematic to check if I wired it correctly?
Please assist as it makes cooking a bit difficult.
Thank you.
