Discuss
Whirlpool Dbl Oven E6 F2 code
 in
Whirlpool dbl oven Mod#RBD305PDB15 (4 yrs old) Periodically sounds tones, then stops working except interior light, oven comes back on
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Dbl Oven E6 F2 code
  #1 (permalink)
Old 12-29-2009, 12:07 PM
Junior Member
themalones1995@gmail.com is on a distinguished road
Default Whirlpool Dbl Oven E6 F2 code
Model Number: RBD305PDB15   Brand: Whirlpool   Age: 1 - 5 years
Whirlpool dbl oven Mod#RBD305PDB15 (4 yrs old) Periodically sounds tones, then stops working except interior light, oven comes back on (with tones) within a few minutes to several days,w/ code E6 F2 on display, then works fine.
Needs new Control panel assy? P/N AP3131744, if so, need proper procedure to remove old panel assembly w/membrane...
Could it be Electronic control circuit? P/N AP3598617
Or Sensor? AP4321511
Or Thermostat(TOD)? P/N AP3885687
or Transformer? P/N AP3968801,
Or Electronic clock control board? P/N AP3595759,
Or Thermal Fuse? P/N AP33249... What's your best guess?, (two are not in stock on this website, by the way.;electronic clock control board,electronic control circuit) Thanks.
Related Models
Whirlpool RBD305PDB15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDB2 ELECTRIC OVEN
Whirlpool RBD305PDB3 ELECTRIC OVEN
Whirlpool RBD305PDB4 ELECTRIC OVEN
Whirlpool RBD305PDB6 ELECTRIC OVEN
Whirlpool RBD305PDB7 ELECTRIC OVEN
Whirlpool RBD305PDB8 ELECTRIC OVEN
Whirlpool RBD305PDB9 ELECTRIC OVEN
Whirlpool RBD305PDQ1 ELECTRIC OVEN
Whirlpool RBD305PDQ10 ELECTRIC OVEN
Whirlpool RBD305PDQ11 ELECTRIC OVEN
Whirlpool RBD305PDQ12 ELECTRIC OVEN
Whirlpool RBD305PDQ13 ELECTRIC OVEN
Whirlpool RBD305PDQ14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDQ15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDQ2 ELECTRIC OVEN
Whirlpool RBD305PDQ3 ELECTRIC OVEN
Whirlpool RBD305PDQ4 ELECTRIC OVEN
Whirlpool RBD305PDQ6 ELECTRIC OVEN
Whirlpool RBD305PDQ7 ELECTRIC OVEN
Whirlpool RBD305PDQ8 ELECTRIC OVEN
Whirlpool RBD305PDQ9 ELECTRIC OVEN
Whirlpool RBD305PDS12 ELECTRIC OVEN
Whirlpool RBD305PDS14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDS15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDT11 ELECTRIC OVEN
Whirlpool RBD305PDT12 ELECTRIC OVEN
Whirlpool RBD305PDT13 ELECTRIC OVEN
Whirlpool RBD305PDT14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDT15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRB00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRB02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRQ00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRQ02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRS00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRS02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRT00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRT02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVB00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVB02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVB03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD305PVQ00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVQ02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVQ03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD305PVS00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVS02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVT00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVT02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVT03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDB1 Built-In Oven, Electric
Whirlpool RBD306PDB10 OVEN
Whirlpool RBD306PDB11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDB12 OVEN
Whirlpool RBD306PDB13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDB14 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDB15 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDB2 Built-In Oven, Electric
Whirlpool RBD306PDB4 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDB6 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDB7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDB8 ELECTRIC WALL OVEN
Whirlpool RBD306PDB9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDQ1 Built-In Oven, Electric
Whirlpool RBD306PDQ10 OVEN
Whirlpool RBD306PDQ11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDQ12 OVEN
Whirlpool RBD306PDQ13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDQ14 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDQ15 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDQ2 Built-In Oven, Electric
Whirlpool RBD306PDQ4 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDQ6 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDQ7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDQ8 ELECTRIC WALL OVEN
Whirlpool RBD306PDQ9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDT11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDT12 OVEN
Whirlpool RBD306PDT13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDT14 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDT15 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDZ1 30" BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDZ10 OVEN
Whirlpool RBD306PDZ2 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDZ4 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDZ6 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDZ7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDZ8 ELECTRIC WALL OVEN
Whirlpool RBD306PDZ9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD307PDB1 ELECTRIC OVEN
Whirlpool RBD307PDB2 ELECTRIC OVEN
Whirlpool RBD307PDQ1 ELECTRIC OVEN
Whirlpool RBD307PDQ2 ELECTRIC OVEN
Whirlpool RBD307PDQ4 ELECTRIC OVEN
Whirlpool RBD307PVB00 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEAN
Whirlpool RBD307PVB02 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Whirlpool RBD307PVB03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD307PVQ00 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEAN
Whirlpool RBD307PVQ02 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Whirlpool RBD307PVQ03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD307PVS00 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEAN
Whirlpool RBD307PVS02 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Whirlpool RBD307PVS03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Maytag RBE170PA REF - TOP MOUNT
Maytag RBE170PW REF - TOP MOUNT
Maytag RBE170TA REF - TOP MOUNT
Maytag RBE170TM REF - TOP MOUNT
Maytag RBE170TV REF - TOP MOUNT
Maytag RBE170TW REF - TOP MOUNT
Maytag RBE17KA-0A REF - TOP MOUNT
Maytag RBE17KN-0A REF - TOP MOUNT
Maytag RBE193PA REF - TOP MOUNT
Maytag RBE193PW REF - TOP MOUNT
Maytag RBE193TA REF - TOP MOUNT
Maytag RBE193TM REF - TOP MOUNT
Maytag RBE193TV REF - TOP MOUNT
Maytag RBE193TW REF - TOP MOUNT
Maytag RBE19KA-3A REF - TOP MOUNT
Maytag RBE19KN-3A REF - TOP MOUNT
Maytag RBE19KY-3A REF - TOP MOUNT
Maytag RBE214AFM REF - TOP MOUNT
  #2 (permalink)
Old 12-29-2009, 02:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad control panel. Less likely, but still possible - a bad control board. You can find some useful information in one of our previous threads: Whirlpool fault code E6 F2
If any part is shown on this site as out of stock, you can always talk to their team and they will give you the ETA.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dbl Oven E6 F2 code themalones1995@gmail.com Oven Repair (including Ranges and Cooktops) 0 12-31-2009 07:18 AM
Whirlpool Oven code F3 cdrisdale Oven Repair (including Ranges and Cooktops) 1 02-27-2009 04:24 PM
E6 F2 Code on Whirlpool Oven sonny9 Oven Repair (including Ranges and Cooktops) 1 12-24-2008 11:56 AM
Whirlpool Oven error code E3 F1 Alamo1 Oven Repair (including Ranges and Cooktops) 0 06-12-2008 04:16 PM
F3 Code Whirlpool Oven hershey968 Oven Repair (including Ranges and Cooktops) 0 06-04-2008 08:03 AM
