Discuss
Igniter installation for Tappan Oven
 in
I have received the ignitor from this site and have a few question on installation I have removed the oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Igniter installation for Tappan Oven
  #1 (permalink)
Old 03-23-2008, 06:35 PM
almah1 almah1 is offline
Junior Member
almah1 is on a distinguished road
Default Igniter installation for Tappan Oven
Model Number: 30806637e7063   Brand: Tappan   Age: More than 10 years
I have removed the oven floor and baffle I can see the burner and ignitor but the wires go down through into the back floor of the oven. can i splice the ignitor here or should i try to locate the other end near the valve
Also does it matter which wire on the new ignitor goes which wire on the old connector that i will splice in
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-24-2008, 01:51 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
You can definitely splice the igniter from inside of the oven and it does not matter which wire where goes.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-25-2008, 09:27 PM
Junior Member
Default
Gene thanks for the quick reply oven is working like new The two screws that attach igniter to burner were frozen on I had to drill out the screws and use new screws there must be a easier way to remove old screws whats your secret?
Also the stove top center burner (grill) does not light I hear no clicking sound i have to use a starter stick to light it all other burners work fine the right front burner s a little slow to start maybe take 15-20 clicks before it starts with a big poof
  #4 (permalink)
Old 03-26-2008, 08:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix the oven.
Most likely the problem with the grill is a bad ignition switch and the right front burner probably needs cleaning. For more accurate advise I need the right model number of the range. The model number you posted is incorrect.
__________________
  #5 (permalink)
Old 03-26-2008, 11:26 PM
Junior Member
Default
model TGF657BFB1
  #6 (permalink)
Old 03-29-2008, 12:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The part number for the ignition switch is AP2124410
Looking at the burner you can see a few holes around the top part of the burner and a few vertical holes from the ignition side. It is very important to have all these holes open. You can use any sharp pin (like a toothpick) to unblock them.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Igniter installation for Tappan Oven almah1 Oven Repair (including Ranges and Cooktops) 0 03-16-2008 01:06 AM
Tappan Oven Niteshay Oven Repair (including Ranges and Cooktops) 2 02-29-2008 06:29 PM
Tappan Gas Oven Igniter going bad? Amps? John Fisher Oven Repair (including Ranges and Cooktops) 1 01-24-2008 07:16 PM
Igniter installation for Tappan Oven robbi6250 Oven Repair (including Ranges and Cooktops) 3 12-29-2007 02:31 PM
Tappan Oven Chuck McCance Oven Repair (including Ranges and Cooktops) 2 11-20-2007 09:27 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
