Discuss
No power after self clean; door locked
 in
I was self-cleaning the upper oven of my Whirlpool double wall oven when it completely shut down mid-cycle.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » No power after self clean; door locked
  #1 (permalink)
Old 03-22-2008, 08:59 PM
mulean mulean is offline
Junior Member
mulean is on a distinguished road
Default No power after self clean; door locked
Model Number: RBD275PDB   Brand: Whirlpool   Age: More than 10 years
I was self-cleaning the upper oven of my Whirlpool double wall oven when it completely shut down mid-cycle. No display on panel and door is locked, even after cool down. Circuit breaker ok. Heard there is a thermal fuse somewhere behind the oven, but don't know how to access it (remove oven from wall?). Also, is there any way in the interim to get the door open so I can get the last numbers of the model number? There appears to be 2 different thermal fuse/thermistor part numbers, depending upon the model. Any help would be greatly appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-23-2008, 02:58 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
You can find the complete instructions how to open the control panel and the oven door in one of previous posts: Whirlpool Double wall oven DEAD after self cleaning cycle rbd306pd
Post the complete model number and we'll help you with the right part numbers.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-26-2008, 07:18 PM
Junior Member
Default
Gene, thanks for the link. Removed the control panel, was able to depress the solenoid to open the door and get the model number (RBD275PDB6). Also checked both the control panel thermal fuse and the thermistor on the rear of the oven for continuity per the schematic located in the control panel cavity and both appear to be blown (no continuity). I will replace both, one of which involves removing the oven, and hopefully I will be up and running. Part numbers are AP3008987 and AP3110028. Thanks again
  #4 (permalink)
Old 03-26-2008, 09:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep me updated, please and try not to use the self clean anymore.
__________________
  #5 (permalink)
Old 03-29-2008, 02:20 PM
Junior Member
Default
Gene,
I installed both new fuses and everything now works fine. Verified that they were both blown. Over the ten years I have owned the wall oven, I have self-cleaned it many times with no problems until the last time. Do you still recommend not using the self clean cycle? Is it a "hit or miss" as to whether the fused will blow or not?
  #6 (permalink)
Old 03-29-2008, 02:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It was one of most common problems with these ovens: improper air flow through the top and the back of the oven during self clean, causing overheating.
Whirlpool recommended to replace the whole blower assembly and to install an extra glass in the upper oven door to fix it. This is pretty complicated job with much over a 100 bucks for parts.
You have three options: forget about self clean, try to use self clean and be prepared to replace the fuses again or install the kit, recommended by Whirlpool to fix this problem.
__________________
  #7 (permalink)
Old 03-29-2008, 05:17 PM
Junior Member
Default
Thanks for the info Gene....When the oven overheated, I used an ordinary house fan, blowing into the intake grill under the control panel to cool it down. Do you think that might help during the self clean cycle to increase the air flow? Wouldn't be a big deal to do since I don't self clean the oven that often
  #8 (permalink)
Old 03-29-2008, 07:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
No, I do not think it's a good idea. Actually using such fan could make it even worse.
__________________
  #9 (permalink)
Old 03-30-2008, 07:55 AM
Junior Member
Default
OK...I'll take your advice and stay away from using the clean cycle. thanks for all your help
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Door Latch Locked W/O Door hseeger Oven Repair (including Ranges and Cooktops) 2 12-28-2007 12:42 PM
oven door locked sid Oven Repair (including Ranges and Cooktops) 0 11-15-2007 08:58 PM
Door Locked Open chrisc2007 Washer Repair 1 11-14-2007 08:58 PM
Door latch broken/Door locked kitade Dishwasher Repair 2 10-23-2007 11:42 AM
My oven door just locked on it's own Braidqueen Oven Repair (including Ranges and Cooktops) 0 09-05-2007 02:33 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
