| » Replaced the igniter and there is still no heat in my oven??!! |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: 30-3457-00/11054-11080435 Brand: Tappan Age: More than 10 years
Ok, I replaced the igniter, and it glows...yet there is still no heat in my oven! What else can be wrong???
Ruben,
Do you own a voltmeter? Check the oven safety valve for continuity. Open=bad, closed=good. While you're in there, get all the numbers off the old valve and post them here. Igniters fail much more often than safety valves. I don't want to include any "statistics" here , I haven't been really keeping track, but it feels like you'd replace at least a hundred igniters before you get to a failed safety valve.You can properly check the oven igniter with a meter by measuring amps. The safety valve clearly states how many amps. But most people do not own a good amp meter or a multimeter and/or don't know how to use it. So to make this repair as painless as possible (if not 100% accurate), and based on what symptoms they give me, I would usually recommend replacing the oven igniter. Works in most cases, unfortunately not in yours. |
| Display Modes | |
| never replaced a drive belt before | stonebuster | Washer Repair | 0 | 08-10-2007 04:23 PM |
| Igniter glows but no flame. | zab | Dryer Repair | 1 | 08-06-2007 06:55 PM |
| Removing dryer cabinet to repair igniter | Mikeofba | Dryer Repair | 1 | 07-27-2007 10:48 PM |
| Oven won't heat up at all. | acillatem | Oven Repair (including Ranges and Cooktops) | 27 | 07-26-2007 11:32 PM |
| Oven wont heat to temp | rickm1959 | Oven Repair (including Ranges and Cooktops) | 1 | 07-24-2007 03:52 PM |
