Discuss
kitchenaid range/oven kgst300bwh1 'Err' fault code when over 260 deg
 in
Hi! Any help on this is greatly appreciated! Bought installed in 1996 by previous home owner. it's a kitchenaid
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » kitchenaid range/oven kgst300bwh1 'Err' fault code when over 260 deg
  #1 (permalink)
Old 03-21-2008, 10:32 PM
dansanjose dansanjose is offline
Junior Member
dansanjose is on a distinguished road
Question kitchenaid range/oven kgst300bwh1 'Err' fault code when over 260 deg
Model Number: kgst300bwh1   Brand: Kitchen Aid   Age: More than 10 years
Hi!
Bought installed in 1996 by previous home owner. it's a kitchenaid range/oven kgst300bwh1, issue is it shows 'Err' fault code when attempting to enter any temperature over 260 deg in both bake and broil mode.
Any temperature is accepted under 260 degrees.
I referenced some other forum from "Jake", which stated replacing both the control board and microcomputer board, did not resolve the issue. (posted today, 3/21/08).
I also turned off the breaker for a few moments, with no change in symptoms.
Any advice, greatly appreciated.
My girlfriend is hungry, so we're off for pizza tonight instead.
Thanks.
Hungry Dan, in San Jose.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-22-2008, 03:46 PM
edo edo is offline
Junior Member
edo is on a distinguished road
Default
See this link. It’s probably a simple fix.
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/3996-err-message-when-trying-bake-above-260-a.html
Happy Easter!
Ed
  #3 (permalink)
Old 03-22-2008, 03:49 PM
Junior Member
Default
Awesome Ed, thank you so much! We are happy, and our stomachs are full.
Happy Easter to you too!
Dan.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven does not work after self clean. Shows fault code F1 Nicolez123 Oven Repair (including Ranges and Cooktops) 3 02-11-2008 12:06 PM
Kitchenaid Oven Error code question MSA959 Oven Repair (including Ranges and Cooktops) 0 01-09-2008 01:13 PM
Whirlpool double Oven Fault Code E6 sjarrad Oven Repair (including Ranges and Cooktops) 1 11-20-2007 07:06 PM
CE Fault Code collins66 Washer Repair 0 10-23-2007 09:02 AM
GE Oven Fault Code F7 tmcd1983 Oven Repair (including Ranges and Cooktops) 0 09-12-2007 06:26 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
