Instructions on how to replace tubing (P/N AP4098196) for the pilot light?
What i there to say here but, find one end of the old one, and find the other end, and remove it, and replace with the new one. Shut the gas off before you start, and unplug the oven!! Tom ApplianceEducator.com
Originally Posted by: kayakcrzy What i there to say here but, find one end of the old one, and find the other end, and remove it, and replace with the new one. Shut the gas off before you start, and unplug the oven!! Tom ApplianceEducator.com The line goes behind the back wall of the oven - do I have to pull the oven out? Is the back wall of the oven removable? Can I fish the new line thru the opening of the back wall?
Unfortuantly, you will most likely have to pull the oven, because the gas line will hook up to the gas valve. Did you take the bottom of the oven floor out to see if you can fish it through. If not, the oven has to be pulled. Tom ApplianceEducator.com
