Discuss
Jenn-Air Cooktop Igniter Replacement
 in
Hi: I believe that 1 or 2 of my igniters are bad on my Jenn-Air cooktop. They sometimes keep clicking
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air Cooktop Igniter Replacement
  #1 (permalink)
Old 12-23-2009, 09:32 AM
Junior Member
bmmiller139 is on a distinguished road
Default Jenn-Air Cooktop Igniter Replacement
Model Number: cvgx2423   Brand: Jenn-Air   Age: 5 - 10 years
Hi:
I believe that 1 or 2 of my igniters are bad on my Jenn-Air cooktop. They sometimes keep clicking after the the burner ignites or keep clicking after another burner ignites (not the same burner).
The igniters are pretty cheap about $13. But how do I replace?
Do I take the nut of the top of the burner (gas) or do I need to take out the pan? If it is the pan that needs to be removed, I have already tried taking out all the screws, but it will not separate from the trim. Do I need to lift the whole unit out?
Any help greatly appreciated. Thanks.
Ads By Google
Related Models
Jenn-Air CVGX2423B Surface Base Unit - Ddraft Gas
Jenn-Air CVGX2423Q Surface Base Unit - Ddraft Gas
Jenn-Air CVGX2423W Surface Base Unit - Ddraft Gas
Whirlpool CVR1000
Whirlpool CVR2000
Whirlpool CVR3000
Whirlpool CVR500
Whirlpool CVR600
Whirlpool CVR6001
Thermador CVS30RB
Thermador CVS30RS
Thermador CVS30RW
Thermador CVS36RB
Thermador CVS36RS
Thermador CVS36RW
Thermador CVS45RB
Thermador CVS45RS
Thermador CVS45RW
Thermador CVSE36B
Crosley CW18C1 Washer - Top Loading
Crosley CW18C100 Washer - Top Loading
Crosley CW18C124 Washer - Top Loading
Crosley CW18C125 Washer - Top Loading
Crosley CW18C126 Washer - Top Loading
Crosley CW18C127 Washer - Top Loading
Crosley CW18C1A Washer - Top Loading
Crosley CW18C1H Washer - Top Loading
Crosley CW18C3A Washer - Top Loading
Crosley CW18C3H Washer - Top Loading
Crosley CW18C3W Washer - Top Loading
Crosley CW18M4 Washer - Top Loading
Crosley CW18M4A Washer - Top Loading
Crosley CW18M4H Washer - Top Loading
Crosley CW18M4W Washer - Top Loading
Crosley CW18P2A Washer - Top Loading
Crosley CW18P2AC Washer - Top Loading
Crosley CW18P2H Washer - Top Loading
Crosley CW18P2HC Washer - Top Loading
Crosley CW18P2W Washer - Top Loading
Crosley CW18P2WC Washer - Top Loading
Crosley CW18P6A Washer - Top Loading
Crosley CW18P6H Washer - Top Loading
Crosley CW18P6W Washer - Top Loading
Crosley CW18T2A Washer - Top Loading
Crosley CW18T2W Washer - Top Loading
Crosley CW20C5A Washer - Top Loading
Crosley CW20C5H Washer - Top Loading
Crosley CW20C5W Washer - Top Loading
Crosley CW20C7A Washer - Top Loading
Crosley CW20C7W Washer - Top Loading
Crosley CW20M4A Washer - Top Loading
Crosley CW20M6 Washer - Top Loading
Crosley CW20M6A Washer - Top Loading
Crosley CW20M8 Washer - Top Loading
Crosley CW20M8A Washer - Top Loading
Crosley CW20M8H Washer - Top Loading
Crosley CW20M9A Washer - Top Loading
Crosley CW20M9N Washer - Top Loading
Crosley CW20P4A Washer - Top Loading
Crosley CW20P4H Washer - Top Loading
Crosley CW20P4W Washer - Top Loading
Crosley CW20P5A Washer - Top Loading
Crosley CW20P5AC Washer - Top Loading
Crosley CW20P5H Washer - Top Loading
Crosley CW20P5HC Washer - Top Loading
Crosley CW20P5W Washer - Top Loading
Crosley CW20P5WC Washer - Top Loading
Crosley CW20P6 Washer - Top Loading
Crosley CW20P6A Washer - Top Loading
Crosley CW20P6AC Washer - Top Loading
Crosley CW20P6H Washer - Top Loading
Crosley CW20P6HC Washer - Top Loading
Crosley CW20P6W Washer - Top Loading
Crosley CW20P6WC Washer - Top Loading
Crosley CW20P8 Washer - Top Loading
Crosley CW20P8A Washer - Top Loading
Crosley CW20P8AC Washer - Top Loading
Crosley CW20P8AS Washer - Top Loading
Crosley CW20P8ASC Washer - Top Loading
Crosley CW20P8D Washer - Top Loading
Crosley CW20P8DS Washer - Top Loading
Crosley CW20P8DSC Washer - Top Loading
Crosley CW20P8H Washer - Top Loading
Crosley CW20P8HS Washer - Top Loading
Crosley CW20P8HSC Washer - Top Loading
Crosley CW20P8W Washer - Top Loading
Crosley CW20P8WC Washer - Top Loading
Crosley CW20P8WS Washer - Top Loading
Crosley CW20P8WSC Washer - Top Loading
Crosley CW20T5A Washer - Top Loading
Crosley CW20T5W Washer - Top Loading
Crosley CW20T5WC Washer - Top Loading
Crosley CW20T6A Washer - Top Loading
Crosley CW20T6AC Washer - Top Loading
Crosley CW20T6W Washer - Top Loading
Crosley CW20T6WC Washer - Top Loading
Crosley CW20T7A Washer - Top Loading
Crosley CW20T7V Washer - Top Loading
Crosley CW20T7W Washer - Top Loading
Crosley CW20T8A Washer - Top Loading
Crosley CW20T8AC Washer - Top Loading
Crosley CW20T8V Washer - Top Loading
Crosley CW20T8VC Washer - Top Loading
Crosley CW20T8W Washer - Top Loading
Crosley CW20T8WC Washer - Top Loading
Crosley CW22B5M Washer - Top Loading
Crosley CW22B5V Washer - Top Loading
Crosley CW22B6M Washer - Top Loading
Crosley CW22B6V Washer - Top Loading
Crosley CW22B7M Washer - Top Loading
Crosley CW22B7V Washer - Top Loading
Crosley CW22B8M Washer - Top Loading
Crosley CW22B8V Washer - Top Loading
Amana CW2303 Washer - Top Loading
Amana CW2303G Washer - Top Loading
Amana CW2303L Washer - Top Loading
Amana CW2303W Washer - Top Loading
Amana CW2502L Washer - Top Loading
Amana CW2502W Washer - Top Loading
  #2 (permalink)
Old 12-23-2009, 01:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
More likely the problem is a bad spark module. You can find the instructions in the Service manual.
Here are the breakdown diagrams and Replacement parts for JENN-AIR CVGX2423B Surface Base Unit - Ddraft Gas | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-13-2013, 08:57 PM
Junior Member
goacom is on a distinguished road
Default
Gene, is there I way I can get access to the manual? The link does not work anymore. I would like to replace my igniters, but cant figure how!
  #4 (permalink)
Old 02-14-2013, 04:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sorry for the broken link. The access to this manual is not available anymore.
What is the complete model number of your stove and what seems to be a problem?
__________________
  #5 (permalink)
Old 02-20-2013, 08:03 PM
Junior Member
Default
Gene,
Thanks for the reply. My model # is CVGX2423B. My problem is identical to that faced by bmmiller139. Specifically, one of my igniters is bad, but I cant seem to be able to remove it. I tried removing the pan by removing the screws along the sides (see picture "pan screws"), but the pan remains stubbornly attached. I tried removing the nut that is attached to the burner base (see picture burner base nut), but it refused to budge. Just in case that particular nut was a problem, I tried loosening the nut on the other bases, but had the same problem. If I can somehow get under the burner base, I think I would be able to get the igniter out.
Thanks for any help you can provide.
  #6 (permalink)
Old 04-06-2013, 07:35 AM
Junior Member
cvbwood is on a distinguished road
Default Igniter swap
Quote:
Originally Posted by goacom View Post
Gene,
I am having the same problem and have tried the same things. Have you found a solution?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-Air Baking Igniter Replacement CWeiss Oven Repair (including Ranges and Cooktops) 0 10-29-2009 11:22 AM
Jenn air range glass cooktop replacement santostefano Oven Repair (including Ranges and Cooktops) 1 04-22-2009 01:40 PM
Jenn Air cooktop glass replacement azmmike Oven Repair (including Ranges and Cooktops) 1 03-17-2009 07:52 PM
Dacor - gas cooktop igniter replacement Meckler Oven Repair (including Ranges and Cooktops) 0 02-13-2009 11:49 AM
Element Replacement on Jenn Air Glass Cooktop Alkraut Oven Repair (including Ranges and Cooktops) 2 03-20-2008 05:56 AM
