Discuss
Wall oven electric not working
 in
Hi,I need help with the repair of my oven, and who to get to come in and repair. I was
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Wall oven electric not working
  #1 (permalink)
Old 12-20-2009, 02:55 PM
Junior Member
dlimes is on a distinguished road
Default Wall oven electric not working
Model Number: cwe9000bce   Brand: Maytag   Age: More than 10 years
I was getting a code F3, and then the element lower one sparked and there was a hole in it. My husband replaced the element that we ordered from appliance pros.
The oven is not getting hot I do not know if it is the sensor, thermostat or what I need help. Can I talk to someone live.
thank you.
Should I purchase a new oven, or is this repairable.
We are unable to turn the broiler knob on - bake goes up to 175 degrees, the bottom element does not heat at all, and the top element gets warm.
please advise.
denise limes
973-243-1277 - home / cell 201-396-0273
Ads By Google
Related Models
Maytag CWE9000BCE Walloven - S/c Ele
Maytag CWE9000BCM Walloven - S/c Ele
Maytag CWE9000BDB Walloven - S/c Ele
Maytag CWE9000BDE Walloven - S/c Ele
Maytag CWE9000CDB Walloven - S/c Ele
Maytag CWE9000CDE Walloven - S/c Ele
Maytag CWE9000DDB Walloven - S/c Ele
Maytag CWE9000DDE Walloven - S/c Ele
Maytag CWE9030BCB Walloven - S/c Ele
Maytag CWE9030BCE Walloven - S/c Ele
Maytag CWE9030BDB Walloven - S/c Ele
Maytag CWE9030BDE Walloven - S/c Ele
Maytag CWE9030DDB Walloven - S/c Ele
Maytag CWE9030DDE Walloven - S/c Ele
Maytag CWE9900 Walloven - S/c Ele
Admiral CWEA100ACB Walloven - Std Ele
White Westinghouse CWEF309ES1 White Westinghouse/electric Range
White Westinghouse CWEF310ES1 White Westinghouse Canada/electric Range
White Westinghouse CWEF310FSA Ww Canada/electric Range
White Westinghouse CWEF311ES1 White Westinghouse/electric Range
White Westinghouse CWEF312ES1 Ww Canada/electric Range
White Westinghouse CWEF312FSA Ww Canada/electric Range
White Westinghouse CWEF312FSB White Westinghouse/range
White Westinghouse CWEF320ES1 Whiet Westinghouse Canada/electric Range
White Westinghouse CWEF322ES1 Ww Canada/electric Range
White Westinghouse CWEF322ES3 W - W Canada/electric Range
White Westinghouse CWEF322ES4 Ww Canada/electric Range
White Westinghouse CWEF322ES5 Ww Canada/electric Range
White Westinghouse CWEF355ES1 White Westinghouse/electric Range
Maytag CWG300 Walloven - Std Gas
Maytag CWG301 Walloven - Std Gas
Maytag CWG302 Walloven - Std Gas
Maytag CWG3020AAB Walloven - Std Gas
Maytag CWG3020AAE Walloven - Std Gas
Maytag CWG3020BAB Walloven - Std Gas
Maytag CWG3020BAE Walloven - Std Gas
Maytag CWG3100AAB Walloven - Std Gas
Maytag CWG3100AAE Walloven - Std Gas
Maytag CWG3100AAS Walloven - Std Gas
Maytag CWG3100AAW Walloven - Std Gas
Maytag CWG351 Walloven - Std Gas
Maytag CWG3510AAB Walloven - Std Gas
Maytag CWG3510BAB Walloven - Std Gas
Maytag CWG3600AAB Walloven - Std Gas
Maytag CWG3600AAE Walloven - Std Gas
Maytag CWG3600AAQ Walloven - Std Gas
Maytag CWG3600AAS Walloven - Std Gas
Maytag CWG400 Walloven - Std Gas
Maytag CWG401 Walloven - Std Gas
Maytag CWG402 Walloven - Cont Clean Gas
Maytag CWG4020AAB Walloven - Cont Clean Gas
Maytag CWG4020BAB Walloven - Cont Clean Gas
Maytag CWG4100AAB Walloven - Std Gas
Maytag CWG450 Walloven - Std Gas
Maytag CWG451 Walloven - Cont Clean Gas
Maytag CWG4510AAB Walloven - Cont Clean Gas
Maytag CWG4510BAB Walloven - Cont Clean Gas
Maytag CWG4600AAB Walloven - Std Gas
Admiral CWGA200AAB Walloven - Cont Clean Gas
Admiral CWGA800AAB Walloven - S/c Gas
Admiral CWGA800AAE Walloven - S/c Gas
Whirlpool CWI1701W0
Whirlpool CWI1701W1
Whirlpool CWI2101W0
Whirlpool CWI2101W1
Frigidaire CWS3600AS0 Fs Washer - Frig/best Buy
Frigidaire CWS3600AS1 Frigidaire/washer
Frigidaire CWS445RGS0 Gib(v0) / Free Standing Washer
Frigidaire CWS445RGS1 Gib(v0) / Free Standing Washer
Maytag CX8670RB Surface Unit - Ele
Maytag CX8670RV Surface Unit - Ele
Maytag CX8670TB Surface Unit - Ele
Maytag CX8670TV Surface Unit - Ele
Maytag CX9875VVV Walloven - S/c Ele
Maytag CX9875VYV Walloven - S/c Ele
Maytag CX9875XYB Walloven - S/c Ele
Whirlpool CXA1300W0
Whirlpool CXA1300W1
Whirlpool CXA1300W2
Whirlpool CXA1300W3
Whirlpool CXA1300W4
Whirlpool CXA1300W5
Whirlpool CXA1300W7
Whirlpool CXA1300W8
Whirlpool CXA1300W9
Whirlpool CXA1700W0
Whirlpool CXA1700W1
Whirlpool CXA1700W3
Whirlpool CXA1700W4
Whirlpool CXA1700W5
Whirlpool CXA1750W0
Whirlpool CXA1750W1
Whirlpool CXA2000W0
Whirlpool CXA2000W1
Whirlpool CXA2000W3
Whirlpool CXA2000W4
Whirlpool CXA2000W5
Whirlpool CXA2500W0
Whirlpool CXA2500W1
Whirlpool CXA2500W3
Whirlpool CXA2500W4
Whirlpool CXA2500W5
Whirlpool CXA3500W0
Whirlpool CXA3500W3
Whirlpool CXA3500W4
Whirlpool CXA3510W0
Whirlpool CXB1400W0
Whirlpool CXB1400W1
Whirlpool CXE1700W0
Whirlpool CXE1700W1
Whirlpool CXE1700W2
Whirlpool CXE1700W3
Whirlpool CXE2100W0
Whirlpool CXE2100W2
Whirlpool CXE2100W3
Whirlpool CXE2100W4
Whirlpool CXI1701W0
Whirlpool CXI1701W1
Whirlpool CXI1701W2
Whirlpool CXI1701W3
  #2 (permalink)
Old 12-21-2009, 03:45 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for MAYTAG CWE9000BCE Walloven - S/c Ele | AppliancePartsPros.com
Note that I do not work for AppliancPartsPros. I am just a DIYer who tries to help out a few people.
I could not find a wiring diagram for this unit so the below is just general info.
Looking at different info sources it looks like usually an F3 error on a Maytag is a sensor error so I would start there by removing it and checking it with a meter. Below is a good link, check out 7, 8, 20 and 21.
Often a spark will take out the control board. Have you turned the breaker for this unit off/on slowly as it may be you are only getting 120 volts and not the full 240 required by the oven. I would check that the 240 is there with a meter. Also check that a wire in the unit has not burned off.
Without a wiring diagram I cannot see how they have wired in the thermostat and the temperature sensor
Sorry but I only do this online, perhaps someone else will help you on the phone.
It is repairable the problem is at what cost. Getting a tech in is probably going to cost $100.00 or so and if you need a control board another $200.00 plus. The unit is starting to get pretty long in the tooth as you can see from the parts listing re: out of stock and requires special attention etc. If it is not repairable by yourselves I would go with a new unit.
Just not worth putting a lot of dollars into it as the next time it goes down you may not be able to get the parts.
This is very strange as the top element (broil) does come on but will not let you use the broil setting yet when in bake mode it will get warm.
A wiring diagram is required to troubleshoot this as you need to know how the temperature sensor and thermostat are wired in, it also has a hi-limit thermostat and a dlb relay.
It does sound like you may have more than one problem. The first being the temperature sensor, the second being the element control issue.
I know the above is not much help but thought I should respond due to the time of year when often an oven is the most important appliance in the kitchen what with family dinners and all.
Hopefully someone else will jump in who has the wiring diagram or experience on this particular unit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
electric wall oven Hshan Oven Repair (including Ranges and Cooktops) 1 01-12-2010 02:52 AM
Westinghouse Electric Wall Oven csmith5716 Oven Repair (including Ranges and Cooktops) 3 07-09-2009 12:17 PM
Jenn Air Wall Electric Wall Oven WILLIAM SHIVER Oven Repair (including Ranges and Cooktops) 3 05-20-2009 12:56 AM
Electric wall oven pendama Oven Repair (including Ranges and Cooktops) 5 05-07-2009 05:36 PM
GE Electric Wall Oven Oppy38 Oven Repair (including Ranges and Cooktops) 0 02-25-2009 02:14 PM
