Discuss
old mobile home gas range - oven is very slow to light
 in
I have a Magic Chef gas range in an old mobile home. It has continuos pilot lights. Burners on top
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » old mobile home gas range - oven is very slow to light
  #1 (permalink)
Old 12-20-2009, 11:46 AM
Junior Member
AONE is on a distinguished road
Default old mobile home gas range - oven is very slow to light
Model Number: u313v-10   Brand: Magic Chef   Age: More than 10 years
I have a Magic Chef gas range in an old mobile home. It has continuos pilot lights. Burners on top work fine. However, the oven takes a long time to light when I first turn it on and during the baking cycle. Had a kinked supply line. Replaced it but still have same problem. Has regulator under range top that is marked Maxitrol RV45C "P". I think this regulator may be for LP gas. But I have Nat. gas supply. Could this be the problem? Could the oven burner be clogged? The delay in oven burner ignition causes baking to take longer and food is not fully cooked in the middle unless I burn it on the outside.
Related Models
Magic Chef U31FA-2W RANGE- F/S STD GAS
Magic Chef U31FA-7 RANGE- F/S STD GAS
Magic Chef U31FA-7-02 RANGE- F/S STD GAS
Magic Chef U31FA-7-CN RANGE- F/S STD GAS
Magic Chef U31FA-7-CP RANGE- F/S STD GAS
Magic Chef U31FA-7-DN RANGE- F/S STD GAS
Magic Chef U31FA-7-DQ RANGE- F/S STD GAS
Magic Chef U31FA-7-EU RANGE- F/S STD GAS
Magic Chef U31FA-7-NK RANGE- F/S STD GAS
Magic Chef U31FA-7K RANGE- F/S STD GAS
Magic Chef U31FA-7K-NK RANGE- F/S STD GAS
Magic Chef U31FA-7LNW RANGE-F/S CONT CLEAN GAS
Magic Chef U31FA-7LNW-04 RANGE-F/S CONT CLEAN GAS
Magic Chef U31FA-7LNX RANGE-F/S CONT CLEAN GAS
Magic Chef U31FA-7LNX-04 RANGE-F/S CONT CLEAN GAS
Magic Chef U31FA-7N RANGE- F/S STD GAS
Magic Chef U31FA-7NW RANGE- F/S STD GAS
Magic Chef U31FA-7NW-AU RANGE- F/S STD GAS
Magic Chef U31FA-7W RANGE- F/S STD GAS
Magic Chef U31FA-7W-02 RANGE- F/S STD GAS
Magic Chef U31FA-7W-04 RANGE- F/S STD GAS
Magic Chef U31FA-7W-DN RANGE- F/S STD GAS
Magic Chef U31FA-8KLW RANGE-F/S CONT CLEAN GAS
Magic Chef U31FA-8KW RANGE- F/S STD GAS
Magic Chef U31FA-8KX-CV RANGE- F/S STD GAS
Magic Chef U31FA-8KX-EL RANGE- F/S STD GAS
Magic Chef U31FA-8KX-ES RANGE- F/S STD GAS
Magic Chef U31FA-8KX-OC RANGE- F/S STD GAS
Magic Chef U31FA-8LW RANGE-F/S CONT CLEAN GAS
Magic Chef U31FA-8LX-EL RANGE-F/S CONT CLEAN GAS
Magic Chef U31FA-8LX-OC RANGE-F/S CONT CLEAN GAS
Magic Chef U31FA-8NW RANGE- F/S STD GAS
Magic Chef U31FA-8NW-AO RANGE- F/S STD GAS
Magic Chef U31FA-8W RANGE- F/S STD GAS
Magic Chef U31FA-8W-02 RANGE- F/S STD GAS
Magic Chef U31FA-8W-DN RANGE- F/S STD GAS
Magic Chef U31FA-8X-AC RANGE- F/S STD GAS
Magic Chef U31FA-8X-CV RANGE- F/S STD GAS
Magic Chef U31FA-8X-EL RANGE- F/S STD GAS
Magic Chef U31FA-8X-ES RANGE- F/S STD GAS
Magic Chef U31FA-8X-OC RANGE- F/S STD GAS
Magic Chef U31FA-92KLW RANGE-F/S CONT CLEAN GAS
Magic Chef U31FA-92KLXY-6E RANGE-F/S CONT CLEAN GAS
Magic Chef U31FA-92LW-AD RANGE-F/S CONT CLEAN GAS
Magic Chef U31FA-92LW-AO RANGE-F/S CONT CLEAN GAS
Magic Chef U31FA-92LX-ON RANGE-F/S CONT CLEAN GAS
Magic Chef U31FA-92W RANGE- F/S STD GAS
Magic Chef U31FA-92W-19 RANGE- F/S STD GAS
Magic Chef U31FA-92W-AD RANGE- F/S STD GAS
Magic Chef U31FA-92W-DN RANGE- F/S STD GAS
Magic Chef U31FA-92W-QF RANGE- F/S STD GAS
Magic Chef U31FA-92X-AC RANGE- F/S STD GAS
Magic Chef U31FA-92X-BG RANGE- F/S STD GAS
Magic Chef U31FB-92KW RANGE- F/S STD GAS
Magic Chef U31FG-7LNW RANGE-F/S CONT CLEAN GAS
Magic Chef U31FG-92KW RANGE- F/S STD GAS
Magic Chef U31FK-7 RANGE- F/S STD GAS
Magic Chef U31FK-7-02 RANGE- F/S STD GAS
Magic Chef U31FK-7-30 RANGE- F/S STD GAS
Magic Chef U31FK-7-CN RANGE- F/S STD GAS
Magic Chef U31FK-7-CP RANGE- F/S STD GAS
Magic Chef U31FK-7-DN RANGE- F/S STD GAS
Magic Chef U31FK-7-DQ RANGE- F/S STD GAS
Magic Chef U31FK-7-EU RANGE- F/S STD GAS
Magic Chef U31FK-7-NK RANGE- F/S STD GAS
Magic Chef U31FK-7K RANGE- F/S STD GAS
Magic Chef U31FK-7K-NK RANGE- F/S STD GAS
Magic Chef U31FK-7LNW-04 RANGE-F/S CONT CLEAN GAS
Magic Chef U31FK-7LNX RANGE-F/S CONT CLEAN GAS
Magic Chef U31FK-7LNX-04 RANGE-F/S CONT CLEAN GAS
Magic Chef U31FK-7N RANGE- F/S STD GAS
Magic Chef U31FK-7NW RANGE- F/S STD GAS
Magic Chef U31FK-7NW-AU RANGE- F/S STD GAS
Magic Chef U31FK-7W RANGE- F/S STD GAS
Magic Chef U31FK-7W-02 RANGE- F/S STD GAS
Magic Chef U31FK-7W-04 RANGE- F/S STD GAS
Magic Chef U31FK-7W-DN RANGE- F/S STD GAS
Magic Chef U31FK-8KLW RANGE-F/S CONT CLEAN GAS
Magic Chef U31FK-8KW RANGE- F/S STD GAS
Magic Chef U31FK-8KX-CV RANGE- F/S STD GAS
Magic Chef U31FK-8KX-EL RANGE- F/S STD GAS
Magic Chef U31FK-8KX-ES RANGE- F/S STD GAS
Magic Chef U31FK-8KX-OC RANGE- F/S STD GAS
Magic Chef U31FK-8LW RANGE-F/S CONT CLEAN GAS
Magic Chef U31FK-8LX-EL RANGE-F/S CONT CLEAN GAS
Magic Chef U31FK-8LX-OC RANGE-F/S CONT CLEAN GAS
Magic Chef U31FK-8NW RANGE- F/S STD GAS
Magic Chef U31FK-8NW-AO RANGE- F/S STD GAS
Magic Chef U31FK-8W RANGE- F/S STD GAS
Magic Chef U31FK-8W-02 RANGE- F/S STD GAS
Magic Chef U31FK-8W-DN RANGE- F/S STD GAS
Magic Chef U31FK-8X-AC RANGE- F/S STD GAS
Magic Chef U31FK-8X-CV RANGE- F/S STD GAS
Magic Chef U31FK-8X-EL RANGE- F/S STD GAS
Magic Chef U31FK-8X-ES RANGE- F/S STD GAS
Magic Chef U31FK-8X-OC RANGE- F/S STD GAS
Magic Chef U31FK-92KLW RANGE-F/S CONT CLEAN GAS
Magic Chef U31FK-92KLXY-6E RANGE-F/S CONT CLEAN GAS
Magic Chef U31FK-92LW-AD RANGE-F/S CONT CLEAN GAS
Magic Chef U31FK-92LW-AO RANGE-F/S CONT CLEAN GAS
Magic Chef U31FK-92LX-ON RANGE-F/S CONT CLEAN GAS
Magic Chef U31FK-92W RANGE- F/S STD GAS
Magic Chef U31FK-92W-19 RANGE- F/S STD GAS
Magic Chef U31FK-92W-AD RANGE- F/S STD GAS
Magic Chef U31FK-92W-DN RANGE- F/S STD GAS
Magic Chef U31FK-92W-QF RANGE- F/S STD GAS
Magic Chef U31FK-92X-AC RANGE- F/S STD GAS
Magic Chef U31FK-92X-BG RANGE- F/S STD GAS
Magic Chef U31FN-2W RANGE- F/S STD GAS
Magic Chef U31FN-7 RANGE- F/S STD GAS
Magic Chef U31FN-7-02 RANGE- F/S STD GAS
Magic Chef U31FN-7-CN RANGE- F/S STD GAS
Magic Chef U31FN-7-CP RANGE- F/S STD GAS
Magic Chef U31FN-7-DN RANGE- F/S STD GAS
Magic Chef U31FN-7-DQ RANGE- F/S STD GAS
Magic Chef U31FN-7-EU RANGE- F/S STD GAS
Magic Chef U31FN-7-NK RANGE- F/S STD GAS
Magic Chef U31FN-7K RANGE- F/S STD GAS
Magic Chef U31FN-7K-NK RANGE- F/S STD GAS
Magic Chef U31FN-7LNW RANGE-F/S CONT CLEAN GAS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven slow to light, smells of gas Dej Oven Repair (including Ranges and Cooktops) 0 01-04-2010 11:04 PM
Oven won't stay warm and is slow to light amanda4242 Oven Repair (including Ranges and Cooktops) 0 08-11-2009 07:43 PM
Oven slow to light moonman Oven Repair (including Ranges and Cooktops) 4 11-26-2008 06:13 AM
Oven slow to light lfd39 Oven Repair (including Ranges and Cooktops) 7 07-29-2008 04:19 PM
Home, home on the range jbell Oven Repair (including Ranges and Cooktops) 1 05-27-2008 07:12 PM
