Discuss
Whirlpool Electric Range
 in
I replaced the control unit on the stove a year ago - clock set button & oven start didn't work.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Electric Range
  #1 (permalink)
Old 03-19-2008, 05:21 PM
jschee jschee is offline
Junior Member
jschee is on a distinguished road
Default Whirlpool Electric Range
Model Number: RF386PXDB1   Brand: Whirlpool   Age: More than 10 years
I replaced the control unit on the stove a year ago - clock set button & oven start didn't work. Everything appeared to work fine after I replace it, but I didn't check to see if Oven Clean feature worked. We seldom use the oven & normally don't get it dirty. Now it is dirty and when we turn on self-cleaning we get a "door" error message. I unplugged & pulled back off and get continuity on oven lock switch at the control unit when I lock for cleaning and open when self-cleaning lock is not engaged. Is there anything other than the control unit that can cause this failure. Oven works fine otherwise - both elements! Just can't clean it!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-19-2008, 07:09 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
What error code exactly was shown on the display?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-19-2008, 07:54 PM
Junior Member
Default error code
It was not a numerical error code. It was in plain english!!! DOOR
  #4 (permalink)
Old 03-20-2008, 05:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check the wires from the switch to the control board and the plug at the control board.
If there is nothing wrong then the problem is a bad control board.
__________________
  #5 (permalink)
Old 03-20-2008, 06:16 PM
Junior Member
Default
Thanks, When I checked the switch I checked it at the control panel including wiring to switch, so guess its control panel. I figured it had to be, I just didn't want to spend a couple hundred for it and have it not fix the problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Electric Range Won't turn off carlynew Oven Repair (including Ranges and Cooktops) 5 07-22-2008 05:08 PM
Electric Range TREFFJ Oven Repair (including Ranges and Cooktops) 4 01-15-2008 12:35 PM
electric range oven augiem Oven Repair (including Ranges and Cooktops) 1 10-28-2007 10:59 AM
Electric Range Oven mpatterson Oven Repair (including Ranges and Cooktops) 0 10-18-2007 08:50 AM
electric range 8 inch burner handiman Oven Repair (including Ranges and Cooktops) 4 09-10-2007 10:22 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
