Discuss
Oven will not keep temperature
 in
We have a dual oven Maytag. The upper oven works great. The lower oven will turn on and heat to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven will not keep temperature
  #1 (permalink)
Old 12-17-2009, 04:50 PM
Junior Member
daholloway is on a distinguished road
Question Oven will not keep temperature
Model Number: MER 6875AAQ   Brand: Maytag   Age: 1 - 5 years
We have a dual oven Maytag. The upper oven works great. The lower oven will turn on and heat to the set temperature. After about 2 cycles it will heat up and not turn off. The elements continue to stay on. We replaced the temperature sensor and it did nothing to solve the problem. I was told the next step is the control panel. This is a spendy item. Any other possibilities?
Ads By Google
Related Models
Maytag MER1140AAW Range - F/s Std Ele
Maytag MER1350AAW Range - F/s Std Ele
Maytag MER2350AAW Range - F/s Cont Clean Ele
Maytag MER4110AAH Range - F/s Std Ele
Maytag MER4110AAW Range - F/s Std Ele
Maytag MER4120AAW Range - F/s Std Ele
Maytag MER4320AAA Range - F/s Std Ele
Maytag MER4320AAW Range - F/s Std Ele
International MER4320AGH Range - F/s Std Ele
International MER4320AGW Range - F/s Std Ele
Maytag MER4326AAA Range - F/s Std Ele
Maytag MER4326AAW Range - F/s Std Ele
International MER4326AGW Range - F/s Std Ele
Maytag MER4351AAB Range - F/s Std Ele
Maytag MER4351AAQ Range - F/s Std Ele
Maytag MER4351AAW Range - F/s Std Ele
International MER4351AGW Range - S/c F/s Ele
Maytag MER4530AAA Range - F/s Std Ele
Maytag MER4530AAH Range - F/s Std Ele
Maytag MER4530AAL Range - F/s Std Ele
Maytag MER4530AAQ Range - F/s Std Ele
Maytag MER4530AAW Range - F/s Std Ele
Maytag MER4530ACH Range - F/s Std Ele
Maytag MER4530ACL Range - F/s Std Ele
Maytag MER4530ACW Range - F/s Std Ele
Maytag MER4530BCW Range - F/s Std Ele
Maytag MER5510AAH Range - S/c F/s Ele
Maytag MER5510AAL Range - S/c F/s Ele
Maytag MER5510AAT Range - S/c F/s Ele
Maytag MER5510AAW Range - S/c F/s Ele
Maytag MER5510BAB Range - S/c F/s Ele
Maytag MER5510BAQ Range - S/c F/s Ele
Maytag MER5510BAW Range - S/c F/s Ele
Maytag MER5511BAQ Range - S/c F/s Ele
Maytag MER5511BAW Range - S/c F/s Ele
Maytag MER5520AAQ Range - S/c F/s Ele
Maytag MER5520AAW Range - S/c F/s Ele
Maytag MER5530AAH Range - S/c F/s Ele
Maytag MER5530AAL Range - S/c F/s Ele
Maytag MER5530AAT Range - S/c F/s Ele
Maytag MER5530AAW Range - S/c F/s Ele
Maytag MER5530ACW Range - S/c F/s Ele
Maytag MER5530BAB Range - S/c F/s Ele
Maytag MER5530BAQ Range - S/c F/s Ele
Maytag MER5530BAW Range - S/c F/s Ele
International MER5530BGW Range - S/c F/s Ele
Maytag MER5550AAA Range - S/c F/s Ele
Maytag MER5550AAH Range - S/c F/s Ele
Maytag MER5550AAL Range - S/c F/s Ele
Maytag MER5550AAQ Range - S/c F/s Ele
Maytag MER5550AAT Range - S/c F/s Ele
Maytag MER5550AAW Range - S/c F/s Ele
Maytag MER5550BAB Range - S/c F/s Ele
Maytag MER5550BAQ Range - S/c F/s Ele
Maytag MER5550BAW Range - S/c F/s Ele
Maytag MER5551AAB Range - S/c F/s Ele
Maytag MER5551AAQ Range - S/c F/s Ele
Maytag MER5551AAS Range - S/c F/s Ele
Maytag MER5551AAW Range - S/c F/s Ele
Maytag MER5551BAB Range - S/c F/s Ele
Maytag MER5551BAQ Range - S/c F/s Ele
Maytag MER5551BAW Range - S/c F/s Ele
Maytag MER5552AAB Range - S/c F/s Ele
Maytag MER5552AAQ Range - S/c F/s Ele
Maytag MER5552AAS Range - S/c F/s Ele
Maytag MER5552AAW Range - S/c F/s Ele
Maytag MER5552BAB Range - S/c F/s Ele
Maytag MER5552BAQ Range - S/c F/s Ele
Maytag MER5552BAS Range - S/c F/s Ele
Maytag MER5552BAW Range - S/c F/s Ele
Maytag MER5555QAB Range - S/c F/s Ele
Maytag MER5555QAQ Range - S/c F/s Ele
Maytag MER5555QAW Range - S/c F/s Ele
Maytag MER5555QCB Range - S/c F/s Ele
Maytag MER5555QCW Range - S/c F/s Ele
Maytag MER5555RCB Range - S/c F/s Ele
Maytag MER5555RCW Range - S/c F/s Ele
Maytag MER5570AAA Range - S/c F/s Ele
Maytag MER5570AAQ Range - S/c F/s Ele
Maytag MER5570AAW Range - S/c F/s Ele
Maytag MER5570ACA Range - S/c F/s Ele
Maytag MER5570ACQ Range - S/c F/s Ele
Maytag MER5570ACW Range - S/c F/s Ele
Maytag MER5570BCQ Range - S/c F/s Ele
Maytag MER5570BCW Range - S/c F/s Ele
Maytag MER5710AAQ Range - S/c F/s Ele
Maytag MER5710AAW Range - S/c F/s Ele
Maytag MER5720BAF Range - F/s Std Ele
Maytag MER5720BAQ Range - F/s Std Ele
Maytag MER5721BAF Range - F/s Std Ele
Maytag MER5721BAQ Range - F/s Std Ele
Maytag MER5730AAA Range - S/c F/s Ele
Maytag MER5730AAH Range - S/c F/s Ele
Maytag MER5730AAL Range - S/c F/s Ele
Maytag MER5730AAQ Range - S/c F/s Ele
Maytag MER5730AAW Range - S/c F/s Ele
Maytag MER5730ACW Range - S/c F/s Ele
International MER5730AGW Range - S/c F/s Ele
Maytag MER5730BAB Range - S/c F/s Ele
Maytag MER5730BAQ Range - S/c F/s Ele
Maytag MER5730BAW Range - S/c F/s Ele
International MER5730BGW Range - S/c F/s Ele
Maytag MER5750AAA Range - S/c F/s Ele
Maytag MER5750AAB Range - S/c F/s Ele
Maytag MER5750AAW Range - S/c F/s Ele
Maytag MER5750BAB Range - S/c F/s Ele
Maytag MER5750BAQ Range - S/c F/s Ele
Maytag MER5750BAW Range - S/c F/s Ele
Maytag MER5751AAB Range - S/c F/s Ele
Maytag MER5751AAQ Range - S/c F/s Ele
Maytag MER5751AAS Range - S/c F/s Ele
Maytag MER5751AAW Range - S/c F/s Ele
Maytag MER5751ACS Range - S/c F/s Ele
Maytag MER5751ACW Range - S/c F/s Ele
Maytag MER5751BAB Range - S/c F/s Ele
Maytag MER5751BAQ Range - S/c F/s Ele
Maytag MER5751BAS Range - S/c F/s Ele
Maytag MER5751BAW Range - S/c F/s Ele
Maytag MER5752AAB Range - S/c F/s Ele
Maytag MER5752AAQ Range - S/c F/s Ele
  #2 (permalink)
Old 12-18-2009, 02:40 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for MAYTAG MER6875AAQ Freestanding - Double Oven - Electric | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/maytag...s/16026150.pdf
You may want to try the diagnostics.
I would say that the control board is at the top of the list.
Either a electronic component is going or the control relay contacts are pitted and are sticking closed after a few cycles.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Oven temperature Bad jeffdroy Oven Repair (including Ranges and Cooktops) 1 12-22-2009 11:01 PM
Oven temperature nada Oven Repair (including Ranges and Cooktops) 0 09-12-2009 11:43 AM
Cannot set temperature on oven ksnyde01 Oven Repair (including Ranges and Cooktops) 2 01-22-2009 06:42 PM
Oven Temperature Low schredder Oven Repair (including Ranges and Cooktops) 1 09-30-2008 01:51 PM
GE Oven temperature fivermillions Oven Repair (including Ranges and Cooktops) 1 12-25-2007 12:57 PM
