| » oven baking element |
Model Number: fefl79fcc Brand: Frigidaire Age: 1 - 5 years
The oven baking element in my oven blew up....sparks and all. We replace the element and now it still does not work. What should we try next.
Thanks for any help. Ads By Google Related Models |
Remove one terminal from the element, ( LIVE TESTS ) make sure it does not touch anything...turn on the bake cycle, measure the disconnected terminal (meter set to A.C.volts) terminal to ground...Now measure the loose bake terminal to ground you should get 120 volts A.C at both tests. ..Did you measure continuity on the element???? New, bad element....
| Display Modes | |
| Oven Baking Element | kgolden | Oven Repair (including Ranges and Cooktops) | 3 | 08-22-2009 09:00 PM |
| searching for baking element for oven | jkaye | Oven Repair (including Ranges and Cooktops) | 1 | 04-30-2009 08:22 PM |
| Upper Oven Baking Element | bkpierce | Oven Repair (including Ranges and Cooktops) | 1 | 04-09-2009 02:45 AM |
| Kenmore Oven / Top Element Not on when Baking | Shatterbox | Oven Repair (including Ranges and Cooktops) | 2 | 03-29-2009 06:47 PM |
| Oven baking element | DJF | Oven Repair (including Ranges and Cooktops) | 1 | 10-02-2008 10:04 AM |
