Discuss
Oven Locks Up; Can't Turn Heat Off; E1F2
 in
During baking my oven locked up and temp went into high heat. Possibly went into self cleaning mode? Turned off
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Locks Up; Can't Turn Heat Off; E1F2
  #1 (permalink)
Old 12-16-2009, 02:54 PM
Junior Member
amomwhocanfix is on a distinguished road
Question Oven Locks Up; Can't Turn Heat Off; E1F2
Model Number: RBS305PDB14   Brand: Whirlpool   Age: 5 - 10 years
During baking my oven locked up and temp went into high heat. Possibly went into self cleaning mode? Turned off the circuit breaker but the next AM when I turned the circuit breaker back on the oven started by itself and went into high temp again. An error code E1F2 appeared. We just received our ordered part CNTRL-ELEC Whirlpool: 8302994. The heat no longer turns on by itself but the error code E1F2 still appears. Can someone explain the error code?
Ads By Google
Related Models
Whirlpool RBS305PDB14
Whirlpool RBS305PDB16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDB17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDB2
Whirlpool RBS305PDB4
Whirlpool RBS305PDB6
Whirlpool RBS305PDB8
Whirlpool RBS305PDB9
Whirlpool RBS305PDQ1
Whirlpool RBS305PDQ10
Whirlpool RBS305PDQ11
Whirlpool RBS305PDQ12
Whirlpool RBS305PDQ13
Whirlpool RBS305PDQ14
Whirlpool RBS305PDQ16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDQ17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDQ2
Whirlpool RBS305PDQ4
Whirlpool RBS305PDQ6
Whirlpool RBS305PDQ8
Whirlpool RBS305PDQ9
Whirlpool RBS305PDS12
Whirlpool RBS305PDS14
Whirlpool RBS305PDS16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDS17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT10
Whirlpool RBS305PDT11
Whirlpool RBS305PDT12
Whirlpool RBS305PDT13
Whirlpool RBS305PDT14
Whirlpool RBS305PDT16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT8
Whirlpool RBS305PDT9
Whirlpool RBS305PDZ1
Whirlpool RBS305PDZ10
Whirlpool RBS305PDZ2
Whirlpool RBS305PDZ4
Whirlpool RBS305PDZ6
Whirlpool RBS305PDZ8
Whirlpool RBS305PDZ9
Whirlpool RBS305PRB00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRQ00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRS00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRT00 30" Built - in Electric Oven Self Clean
Whirlpool RBS307PDB1
Whirlpool RBS307PDB2
Whirlpool RBS307PDB4
Whirlpool RBS307PDQ1
Whirlpool RBS307PDQ2
Whirlpool RBS307PDQ4
Frigidaire RBSF117E1 BLACK Frg(v3) / Electric Cooktops and Control Box
Frigidaire RBSF117EL1 Frg(v2) / Electric Cooktops and Control Box
Frigidaire RBSF117EW1 Frg(v1) / Electric Cooktops and Control Box
Frigidaire RBSF129EL0 Frg(v4) / Electric Range
Frigidaire RBSF129EW0 Frg(v3) / Electric Range
Frigidaire RBUGCF95ED Frg(v6) / Wall Oven
Frigidaire RBUGCF95EK Frg(v7) / Wall Oven
Frigidaire RBUGCF95EW Frg(v5) / Wall Oven
Amana RC-10B Commercial Microwaves
Amana RC-10B-DD Commercial Microwaves
Amana RC-10B-PB Commercial Microwaves
Amana RC-10D Commercial Microwaves
Amana RC-10PB Commercial Microwaves
Amana RC-10S Commercial Microwaves
Amana RC-10SD Commercial Microwaves
Amana RC-10SE Commercial Microwaves
Amana RC-14 Commercial Microwaves
Amana RC-14B Commercial Microwaves
Amana RC-14S Commercial Microwaves
Amana RC-14SD Commercial Microwaves
Amana RC-14SE Commercial Microwaves
Amana RC-14T Commercial Microwaves
Amana RC-14TD Commercial Microwaves
Amana RC-14TE Commercial Microwaves
Amana RC-20 Commercial Microwaves
Amana RC-20SE Commercial Microwaves
Amana RC-6D Commercial Microwaves
Amana RC-6PB Commercial Microwaves
Amana RC-7D Commercial Microwaves
Amana RC-7PB Commercial Microwaves
Amana RC-8 Commercial Microwaves
  #2 (permalink)
Old 12-17-2009, 05:46 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are the parts
Replacement parts for WHIRLPOOL RBS305PDB14 | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/docs/w...%208301757.pdf
Looks like the ribbon cable from the keypad to the board is not making a good contact.
Try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven locks but won't self-clean MRRQUINN Oven Repair (including Ranges and Cooktops) 3 01-15-2010 05:55 PM
kenmore oven shuts off and door locks rbeck Oven Repair (including Ranges and Cooktops) 0 05-24-2009 06:04 PM
oven door locks for no apparent reason unhuh5591 Oven Repair (including Ranges and Cooktops) 1 11-05-2008 11:03 PM
oven won't turn off, excessive heat jmorrow Oven Repair (including Ranges and Cooktops) 1 08-09-2008 06:33 PM
Oven E1F2 error code CluelessButTrying Oven Repair (including Ranges and Cooktops) 0 03-08-2008 07:25 PM
