Discuss
Runaway Broiler
 in
Gas stove with electronic control. Two examples of my faulty broiler. First, it kicked from low to high on its
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Runaway Broiler
  #1 (permalink)
Old 12-15-2009, 06:05 PM
Junior Member
mikes1127 is on a distinguished road
Default Runaway Broiler
Model Number: 302.75980890   Brand: Kenmore   Age: 5 - 10 years
Two examples of my faulty broiler. First, it kicked from low to high on its own. Turning broiler to OFF on Control ERC did not shut it down. I had to unplug the stove. Second, during BAKE mode the broiler kicked ON and again would not shut off with Control ERC. I had to unplug the unit. I ordered a new Control ERC and installed it. EZ to do. I did this assuming the BROILER function had broken on my existing Control. I was getting fire, so I figured the Ignitor is fine. Well, it did the same kick to HIGH and would not respond to a push of the OFF button still. Had to unplug the unit. So I now have a new Control ERC installed. Should I replace the Iignitor or is there a another part(sensor) I'm not aware of? Thanks
Ads By Google
Related Models
Amana 3021.000 Mwave - Family Size (60 Hz)
Amana 303.000 Mwave - Family Size (60 Hz)
Amana 3036.A00 Mwave - Family Size (60 Hz)
Amana 3072.000 Mwave - Family Size (60 Hz)
Amana 3074.000 Mwave - Family Size (60 Hz)
Amana 3074.A00 Mwave - Family Size (60 Hz)
Amana 3090.000 Mwave - Family Size (60 Hz)
Amana 3094.000 Mwave - Family Size (60 Hz)
Amana 3094.A00 Mwave - Family Size (60 Hz)
Frigidaire 30CGMCWBN1 Tap(v1) / Gas Range
Frigidaire 30CGMCWBN2 Tap(v2) / Gas Range
Frigidaire 30CPMCWBN1 Tap(v1) / Gas Range
Frigidaire 30CPMCWBN2 Tap(v2) / Gas Range
Frigidaire 30CPMCWBN3 Tap(v3) / Gas Range
Frigidaire 30DEMBWDD1 Tap(v1) / Electric Range
Frigidaire 30DEMBWDD1-23 Tap(v2) / Electric Range
Frigidaire 30DEMDWED0 Tap(v1) / Electric Range
Frigidaire 30DEMDWED0-23 Tap(v2) / Electric Range
Frigidaire 30DGMBWDN0 Tap(v1) / Gas Range
Frigidaire 30DGMCWAN4 Tap(v1) / Gas Range
Frigidaire 30DPCDWGN-23-01 Tap(v2) / Gas Range
Frigidaire 30DPCDWGN1 Tap(v1) / Gas Range
Frigidaire 30DPMBWAN6 Tap(v1) / Gas Range
Frigidaire 30DPMBWAP4 Tap(v1) / Gas Range
Frigidaire 30DPMBWAP5 Tap(v2) / Gas Range
Frigidaire 30DPMBWAP6 Tap(v3) / Gas Range
Frigidaire 30DPMCWAN5 Tap(v1) / Gas Range
Frigidaire 30DPMDWEN1 Tap(v1) / Gas Range
Frigidaire 30DPMDWEN1-23 Tap(v2) / Gas Range
Frigidaire 30DPMDWEN2 Tap(v3) / Gas Range
Frigidaire 30DPMDWEN2-23 Tap(v4) / Gas Range
Frigidaire 30DPMDWGN01-23 Tap(v2) / Gas Range
Frigidaire 30DPMDWGN1 Tap(v1) / Gas Range
Frigidaire 30IGCDWAN5 Tap(v1) / Gas Range
Frigidaire 30IPCDWAN5 Tap(v1) / Gas Range
Frigidaire 30IPCDWAN6 Tap(v2) / Gas Range
Frigidaire 30IPCDWAN7 Tap(v1) / Gas Range
Frigidaire 30KEMAWAD3 Tap(v1) / Electric Range
Frigidaire 30KEMAWAD5 Tap(v1) / Electric Range
Frigidaire 30KGMAWAN3 Tap(v1) / Gas Range
Frigidaire 30KGMAWAN3-23 Tap(v2) / Gas Range
Frigidaire 30KGMAWAN4 Tap(v3) / Gas Range
Frigidaire 30KGMAWAN4-23 Tap(v4) / Gas Range
Frigidaire 30KPMAWAN3 Tap(v1) / Gas Range
Frigidaire 30KPMAWAN4 Tap(v2) / Gas Range
Frigidaire 30KPMAWAN5 Tap(v3) / Gas Range
Frigidaire 30KPMAWHN1 Tap(v1) / Gas Range
Frigidaire 30KPMAWHN2 Tap(v1) / Gas Range
Frigidaire 30PPSKWDN0 Tap(v1) / Gas Range
Frigidaire 30PPSKWDN0-23 Tap(v2) / Gas Range
Frigidaire 30PPSKWDN0-32 Tap(v3) / Gas Range
Amana 30R Freezer - Vertical
Amana 30RS Freezer - Vertical
Frigidaire 30TESKWED-04-23 Tap(v2) / Electric Range
Frigidaire 30TESKWED-23 Tap(v2) / Electric Range
Frigidaire 30TESKWED-23-02 Tap(v2) / Electric Range
Frigidaire 30TESKWED-23-03 Tap(v4) / Electric Range
Frigidaire 30TESKWED1 Tap(v1) / Electric Range
Frigidaire 30TESKWED2 Tap(v1) / Electric Range
Frigidaire 30TESKWED3 Tap(v3) / Electric Range
Frigidaire 30TESKWED4 Tap(v1) / Electric Range
Hoover 31
Frigidaire 31-1049-00-01 Tap(v1) / Electric Range
Frigidaire 31-1049-00-02 Tap(v3) / Electric Range
Frigidaire 31-1049-00-03 Tap(v1) / Electric Range
Frigidaire 31-1049-00-04 Tap(v1) / Electric Range
Frigidaire 31-1049-00-05 Tap(v1) / Electric Range
Frigidaire 31-1049-00-06 Tap(v1) / Electric Range
Frigidaire 31-1049-23-01 Tap(v2) / Electric Range
Frigidaire 31-1049-23-02 Tap(v4) / Electric Range
Frigidaire 31-1049-23-03 Tap(v2) / Electric Range
Frigidaire 31-1049-23-04 Tap(v2) / Electric Range
Frigidaire 31-1049-23-05 Tap(v2) / Electric Range
Frigidaire 31-1049-23-06 Tap(v2) / Electric Range
Frigidaire 31-2207-00-01 Tap(v1) / Electric Range
Frigidaire 31-2207-00-02 Tap(v4) / Electric Range
Frigidaire 31-2207-00-03 Tap(v7) / Electric Range
Frigidaire 31-2207-23-01 Tap(v2) / Electric Range
Frigidaire 31-2207-23-02 Tap(v5) / Electric Range
Frigidaire 31-2207-23-03 Tap(v8) / Electric Range
Frigidaire 31-2207-66-01 Tap(v3) / Electric Range
Frigidaire 31-2207-66-02 Tap(v6) / Electric Range
Frigidaire 31-2207-66-03 Tap(v9) / Electric Range
Frigidaire 31-2208-00-01 Tap(v1) / Electric Range
Frigidaire 31-2208-00-02 Tap(v4) / Electric Range
Frigidaire 31-2208-00-03 Tap(v7) / Electric Range
Frigidaire 31-2208-23-01 Tap(v2) / Electric Range
Frigidaire 31-2208-23-02 Tap(v5) / Electric Range
Frigidaire 31-2208-23-03 Tap(v8) / Electric Range
Frigidaire 31-2208-66-01 Tap(v3) / Electric Range
Frigidaire 31-2208-66-02 Tap(v6) / Electric Range
Frigidaire 31-2208-66-03 Tap(v9) / Electric Range
Frigidaire 31-2232-00-01 Tap(v1) / Electric Range
Frigidaire 31-2232-00-02 Tap(v1) / Electric Range
Frigidaire 31-2232-00-03 Tap(v1) / Electric Range
Frigidaire 31-2232-23-01 Tap(v2) / Electric Range
Frigidaire 31-2232-23-02 Tap(v2) / Electric Range
Frigidaire 31-2232-23-03 Tap(v2) / Electric Range
Frigidaire 31-2237-00-01 Tap(v1) / Electric Range
Frigidaire 31-2237-00-02 Tap(v4) / Electric Range
Frigidaire 31-2237-00-03 Tap(v1) / Electric Range
Frigidaire 31-2237-23-01 Tap(v2) / Electric Range
Frigidaire 31-2237-23-02 Tap(v5) / Electric Range
Frigidaire 31-2237-23-03 Tap(v2) / Electric Range
Frigidaire 31-2237-66-01 Tap(v3) / Electric Range
Frigidaire 31-2237-66-02 Tap(v6) / Electric Range
Frigidaire 31-2237-66-03 Tap(v3) / Electric Range
Frigidaire 31-2238-00-05 Tap(v1) / Electric Range
Frigidaire 31-2238-00-06 Tap(v4) / Electric Range
Frigidaire 31-2238-23-05 Tap(v2) / Electric Range
Frigidaire 31-2238-23-06 Tap(v5) / Electric Range
Frigidaire 31-2238-66-05 Tap(v3) / Electric Range
Frigidaire 31-2238-66-06 Tap(v6) / Electric Range
Frigidaire 31-2239-00-01 Tap(v1) / Electric Range
Frigidaire 31-2239-00-02 Tap(v1) / Electric Range
Frigidaire 31-2239-00-03 Tap(v3) / Electric Range
Frigidaire 31-2239-00-04 Tap(v1) / Electric Range
Frigidaire 31-2239-00-05 Tap(v1) / Electric Range
Frigidaire 31-2239-00-06 Tap(v1) / Electric Range
Frigidaire 31-2239-23-01 Tap(v2) / Electric Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Runaway electric oven rigrun Oven Repair (including Ranges and Cooktops) 0 11-16-2009 04:20 PM
maytag oven slow baking plus runaway high temperature russell harris Oven Repair (including Ranges and Cooktops) 2 02-13-2009 10:15 AM
bake temp runaway code on a kitchenaid oven modemdog Oven Repair (including Ranges and Cooktops) 5 09-15-2008 01:53 PM
Wall Oven ~ runaway heating element thomland Oven Repair (including Ranges and Cooktops) 1 01-03-2008 10:37 AM
Oven Temperature Runaway jimk Oven Repair (including Ranges and Cooktops) 1 12-09-2007 12:27 PM
