Discuss
Oven shuts off in bake or broil
 in
Hello All, I love to bake and the holidays are upon us. My oven has decided to take an early
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven shuts off in bake or broil
  #1 (permalink)
Old 12-15-2009, 05:15 PM
Junior Member
njchef is on a distinguished road
Default Oven shuts off in bake or broil
Model Number: FEFL79FCA   Brand: Frigidaire   Age: 1 - 5 years
Hello All,
early vacation. It seems to work fine when just using the range top. When I try to use the oven's bake or broil setting, they initially come on but then the entire unit shuts off about a minute later. Then, the power comes back after about 2 minutes and the clock display starts blinking like the unit was just plugged in. I replaced the Control Panel (EOC) thnking this was the culprit but did not solve the problem. I did a search and did read extensively through the forum but found nothing. Family coming; Please Help!!!!
Thank You,
Eric
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 12-16-2009, 02:20 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here is a wiring diagram
http://manuals.frigidaire.com/prodin.../316441422.pdf
Sounds like you have a bad/loose connection somewhere.
If it should open (disconnect power) for a short time (less that a second) the EOC board (microprocessor) will reset. You would not even notice this on the stove top because it's controls are mechanical.
Flip the breaker off.
Check the receptacle in the wall.
Check the connections at the units terminal strip.
If all OK
Check the connections in the panel at the circuit breaker.
Check the wiring going to the EOC etc.
If all OK
Then it could be the line cord that is no good.
__________________
  #3 (permalink)
Old 12-16-2009, 04:25 AM
Junior Member
Default
Thanks Denman. Will check all when I get home from work tonight.
Eric
  #4 (permalink)
Old 12-16-2009, 06:08 PM
Junior Member
Default
denman,
I followed your advice top to bottom excluding the re-seating the breaker(to hard to get to). I pulled each connection minus the stove top connections off the spade lugs and crimped them. I removed the power supply cord and reconnected it to the terminal. Then I loosed and re-tightened the connections leading to the rest of the unit from the terminal board. Kicked the breaker back on at 7:30pm. As of right now, the oven is kicking along at 400 deg. (up from 350) for 1 1/2 hours. I think
we solved the problem!
THANK YOU!
Eric
  #5 (permalink)
Old 12-17-2009, 04:23 AM
Senior Expert
APP Volunteer
Default
Thanks for getting back to me.
It is nice to know when things work out OK
Have a Happy Holiday Season
__________________
  #6 (permalink)
Old 12-17-2009, 04:06 PM
Junior Member
Default
You too denman. Oven still rockin' and rollin'!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven bake/broil not working after bake element replacement J Justin Oven Repair (including Ranges and Cooktops) 1 11-05-2009 04:36 PM
oven won't bake or broil joekoool3 Oven Repair (including Ranges and Cooktops) 0 09-05-2008 02:31 PM
gas oven no broil or bake joekoool3 Oven Repair (including Ranges and Cooktops) 2 09-05-2008 08:14 AM
GE Gas Oven won't bake or broil... ssacrf Oven Repair (including Ranges and Cooktops) 9 06-27-2008 10:07 PM
Oven won't bake, only broil jae Oven Repair (including Ranges and Cooktops) 6 11-10-2007 09:22 PM
