Discuss
please help
 in
my oven has power but oven and cooktop will not get hot
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » please help
  #1 (permalink)
Old 12-14-2009, 07:12 PM
Junior Member
danichris is on a distinguished road
Default please help
Brand: Frigidaire   Age: 1 - 5 years
  #2 (permalink)
Old 12-14-2009, 07:35 PM
gabe_1981's Avatar
Senior Expert
APP Volunteer
gabe_1981 is on a distinguished road
Default
Please post your complete model number
__________________
Case Appliance Repair College Station,Texas-
  #3 (permalink)
Old 12-14-2009, 07:57 PM
Junior Member
Default
Quote:
frigidarees300
  #4 (permalink)
Old 12-14-2009, 08:00 PM
gabe_1981's Avatar
Senior Expert
APP Volunteer
Default
The model number will be located on a plate on the inner door housing or the housing around the bottom drawer ... You will see model number and serial number both on this plate
__________________
  #5 (permalink)
Old 12-15-2009, 04:22 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Try flipping the breaker off/on slowly a couple times. Often you can loose half the line without actually tripping the breaker. The heating elements require both sides (240 volts) whereas the control panel, lights etc. just require half the line (120 volts).
If this does nothing check the power at the receptacle.
L1 to L2 should be 240 volts
If OK
Unplug the unit
Check the terminal strip in the unit to ensure a wire has not burned off.
If OK
Either check for power at the terminal strip or check the line cord wires for continuity.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
