| » Slide-In Range F13 ERR |
Model Number: PLES389EC Brand: Frigidaire Age: 1 - 5 years
I bought this appliance at Lowes 2 years ago. I received this error once and researched it and found that turning off and on the power resets it, and it worked.
Now it's happening again! It happens everytime I choose any oven heating option. F13 ERR shows up on the display... #$%@#$% and wont go away with power reset! I need any help you may have in fixing this. I do not have warranty and want to fix it myself. Lowes web page: 30-Inch Electric Slide-In Range (Color: Stainless Steel) Info: FrigidaireŽ 30-Inch Electric Slide-In Range (Color: Stainless Steel) Model: PLES389EC Thanks in advance, Jorge Medeiros jorgemede@hotmail.com Last edited by jorgemed : 03-18-2008 at 07:03 AM. Reason: Error in message |
Hi Jorge,
The "F13" error code means "Bad EEPROM identification/Checksum error". If reseting the power did not help then according to Frigidaire suggested corrective action the electronic oven control (aka EOC) has to be replaced. - The part number for the EOC is AP3874704 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Well I have BIG news...
I called Frigidaire (and they were very friendly and helpful) and was told to try and shut the power down, which proceeded to tell them I already tried. They then told me that I have a bad "Clock/Timer, electronic". 20 # 316418735 Clock/Timer, electronic, ES510 as found in the Factory Parts Catalog...Link here: ftp://ftp.electrolux-na.com/ProdInfo...5995449856.pdf But, out of desperation to not waste 160 dollars, I decided to try and shut the power down to the range for a longer time (they only recommend 1 minute). So, after having shut it down at night and getting home after work, I turned the breaker back on and tried the oven and IT'S ALIVE...AGAIN!!! So, to all of you having this problem, turn off the power as long as you can...12 hrs +. Wishing you all best of luck and I hope mine lasts ... very sketchy electronics quality. I will post if anything changes Quote:
Well...the nice looking POS dies shortkly after resetting it (I get a couple uses out of the oven before the F13 error comes back.
I will be buying the $160 part and replacing it myself! No more Frigidaire appliance for me ...I bought 3 Frigidaire appliances at the same time (side by side fridge / Range / and Microwave) and the Refridgerator was returned shortly after (crazy unfixable popping noises problem) and now the Range has bad electronics. I hope the microwave holds up...Does anyone have assembly experience with this part? Are there any good instructions / tips out there??? Quote:
| Display Modes | |
| classic grille (slide -in) hotplates | zeiggy | Oven Repair (including Ranges and Cooktops) | 3 | 02-05-2008 09:35 PM |
| Roper slide in gas range oven problem | dankodrum | Oven Repair (including Ranges and Cooktops) | 0 | 12-13-2007 12:01 PM |
| Kenmore 30" electric self-cleaning slide in range | dennisjane | Oven Repair (including Ranges and Cooktops) | 0 | 11-21-2007 03:18 AM |
| Ceramic Cooktop slide-in oven/stove | EVdelRsoario | Oven Repair (including Ranges and Cooktops) | 1 | 09-19-2007 01:48 PM |
