Discuss
Replacing Dual Element Glass Top Slide In Range
 in
I purchased part number 74002666 (dual element) to replace existing element (inner coil not functioning). This was confirmed to be
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Replacing Dual Element Glass Top Slide In Range
  #1 (permalink)
Old 12-14-2009, 02:34 PM
Junior Member
jack141 is on a distinguished road
Default Replacing Dual Element Glass Top Slide In Range
Model Number: 629.45765   Brand: Kenmore   Age: 5 - 10 years
I purchased part number 74002666 (dual element) to replace existing element (inner coil not functioning). This was confirmed to be the correct part by your customer service. The part appears identical but the ceramic switch-head is different. The instructions included with the part recognizes that the ceramic switch-head of the replacement part may be different, and provides an alternative wiring. My problem is this...the wiring diagrams included with the new part only show 4 wires attached to the element. My original element had 5. The attached pdf shows the wiring diagram received with the new element. Note that the ceramic connector on the new element has a third tab just like my old element. If I put the 5th wire on the empty tab on the ceramic connector block, only the inner coil functions.
Related Models
Maytag 629.45769 KENMORE COOKING
Maytag 629.46775 KENMORE COOKING
Maytag 629.46776 KENMORE COOKING
Maytag 629.46779 KENMORE COOKING
Jenn-Air 629.46965 RANGE- S/C S/I DDRAFT ELE
Jenn-Air 629.46969 RANGE- S/C S/I DDRAFT ELE
Hardwick 629.70131 RANGE- F/S STD GAS
Hardwick 629.70138 RANGE- F/S STD GAS
Hardwick 629.70231 RANGE- F/S STD GAS
Hardwick 629.70238 RANGE- F/S STD GAS
Jenn-Air 629.80515 MISC / ACCESSORY
Jenn-Air 629.80519 MISC / ACCESSORY
Kenmore 62912103 COOKTOPS
Kenmore 62912104 COOKTOPS
Kenmore 62920245 ELECTRIC/GAS SLIDE-IN RANGE
Kenmore 62921136 Built-In Oven, Electric
Kenmore 62921137 Built-In Oven, Electric
Kenmore 62921238 WALL OVEN
Kenmore 62921239 WALL OVEN
Kenmore 62921336 WALL OVEN
Kenmore 62922001 COOKTOP
Kenmore 62922112 COOKTOPS
Kenmore 62922113 COOKTOPS
Kenmore 62922114 UPDRAFT ELECTRIC COOKTOP
Kenmore 62922115 UPDRAFT ELECTRIC COOKTOP
Kenmore 62922116 ELECTRIC COOKTOP
Kenmore 62922401 COOKTOP
Kenmore 62942015 COIL MODULE
Kenmore 62942019 COIL MODULE
Kenmore 62942025 GLASS CARTRIDGE
Kenmore 62942029 GLASS CARTRIDGE
Kenmore 62942032 GRIDDLE MODULE
Kenmore 62942035 GRILL COVER
Kenmore 62942039 GRILL COVER
Kenmore 62942765 ELECTRIC COOKTOP
Kenmore 62942769 ELECTRIC COOKTOP
Kenmore 62942865 ELECTRIC COOKTOP
Kenmore 62942869 ELECTRIC COOKTOP
Kenmore 62942975 COUNTER UNIT
Kenmore 62942975790 COUNTER UNIT
Kenmore 62942979 COUNTER UNIT
Kenmore 62942979790 COUNTER UNIT
Kenmore 6294576 ELECTRIC SLIDE-IN RANGE
Kenmore 62945765 ELECTRIC RANGE
Kenmore 62945765690 ELECTRIC RANGE
Kenmore 62945765790 ELECTRIC RANGE
Kenmore 62945766790 ELECTRIC RANGE
Kenmore 62945769790 ELECTRIC RANGE
Kenmore 62945775 KENMORE COOKING
Kenmore 62945776 KENMORE COOKING
Kenmore 62945779 KENMORE COOKING
Kenmore 62946775690 ELECTRIC RANGE
Kenmore 62946775790 ELECTRIC RANGE
Kenmore 62946776790 ELECTRIC RANGE
Kenmore 62946779790 ELECTRIC RANGE
Kenmore 62946795 ELECTRIC RANGE
Kenmore 62946796 ELECTRIC RANGE
Kenmore 62946799 ELECTRIC RANGE
Kenmore 62946965 ELECTRIC RANGE
Kenmore 62946969 ELECTRIC RANGE
Kenmore 6294697 ELECTRIC RANGE
Kenmore 62946975 WIRING DIAGRAM-RANGE
Kenmore 62946979 WIRING DIAGRAM-RANGE
Kenmore 62960002600 KENMORE COOKING
Kenmore 62960002601 KENMORE COOKING
Kenmore 62960002606 ELECTRIC RANGE
Kenmore 62960003600 KENMORE COOKING
Kenmore 62960008600 KENMORE COOKING
Kenmore 62960008601 KENMORE COOKING
Kenmore 62960008606 ELECTRIC RANGE
Kenmore 62960009600 KENMORE COOKING
Kenmore 62960009601 KENMORE COOKING
Kenmore 62960009606 ELECTRIC RANGE
Kenmore 62970131 GAS RANGE
Kenmore 62970138 GAS RANGE
Kenmore 62990131 ELECTRIC RANGE
Kenmore 62990138 ELECTRIC RANGE
Kenmore 629CG200 GAS COOKTOP
Magic Chef 62S14XAA RANGE- S/I CONT CLEAN GAS
Magic Chef 62S14XAS RANGE- S/I CONT CLEAN GAS
Magic Chef 62S14XAW RANGE- S/I CONT CLEAN GAS
Hoover 63
Amana 630.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 630.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 630.002 RANGE- S/C S/I DDRAFT GAS
Amana 630.003 RANGE- S/C S/I DDRAFT GAS
Frigidaire 6307B WASHER
Frigidaire 6308A WASHER
Frigidaire 6309A WASHER
Amana 631.000 RANGE- S/C S/I DDRAFT GAS
Amana 631.001 RANGE- S/C S/I DDRAFT GAS
Amana 631.002 RANGE- S/C S/I DDRAFT GAS
Amana 631.003 RANGE- S/C S/I DDRAFT GAS
Amana 631.004 RANGE- S/C S/I DDRAFT GAS
Amana 631.006 RANGE- S/C S/I DDRAFT GAS
Amana 632-3J ROOM AIR CONDITIONER
Frigidaire 6337B WASHER
Frigidaire 6338A WASHER
Frigidaire 6339A WASHER
Hoover 634
Frigidaire 6347B WASHER
Frigidaire 6348A WASHER
Frigidaire 6358A WASHER
Frigidaire 6389-80A WASHER
Frigidaire 6389-80B WASHER
Frigidaire 6389-87A WASHER
Frigidaire 6389-87B WASHER
Hoover 64
Maytag 640C DRYER- GAS
Maytag 640W DRYER- GAS
Magic Chef 6458XRA RANGE- S/C S/I GAS
Magic Chef 6458XRS RANGE- S/C S/I GAS
Magic Chef 6458XRW RANGE- S/C S/I GAS
Magic Chef 6458XTA RANGE- S/C S/I GAS
Magic Chef 6458XTS RANGE- S/C S/I GAS
Magic Chef 6458XTW RANGE- S/C S/I GAS
Kenmore 6476037210 KENMORE 30 IN GAS RANGE
Kenmore 6476037220 KENMORE 30 IN GAS RANGE
Kenmore 6476037240 KENMORE 30 IN GAS RANGE
  #2 (permalink)
Old 12-14-2009, 05:27 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
In what position is the "Coil size" switch on the control panel?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-14-2009, 05:45 PM
Junior Member
Default
Gene...
Only the center burner functions whether the switch is in the 6" or 9" position. I tried it both ways thinking I may have switched a wire when I installed the new element.
  #4 (permalink)
Old 12-14-2009, 06:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
According to the wiring diagram the two wires from the infinite switch terminals "H1" & "H2" (outgoing power) should be connected:
"H1" through the limit switch to the common heat element terminal (middle part of both coils);
"H2" has two wires connected. One goes straight to the center coil terminal, supplying power to it as soon as the infinite switch turned "On". The center coil is always "On". The second wire goes through the "Coil size" switch on the control panel and connected to the outside coil, so when 9" size is chosen, it supplies power to the outside coils. At this time both coils are powered up.
I hope it helps.
__________________
  #5 (permalink)
Old 12-19-2009, 07:55 AM
Junior Member
Default
I hope it helps.
Hi Gene...not sure yet if this helps. I'll have to take a closer look at the wiring diagram in your message. It is not the same as the wiring diagram that came with the new element...Jack
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing Maytag glass cootktop element does switch need replacing too? rneumann1962 Oven Repair (including Ranges and Cooktops) 1 01-18-2010 11:19 AM
Kenmore dual-element range pianimal Oven Repair (including Ranges and Cooktops) 0 04-20-2009 02:45 PM
Replacing drop-in range with Slide-in range febrown Oven Repair (including Ranges and Cooktops) 3 03-23-2009 07:54 AM
Replacing element of Maytag Ceramic Top Slide In Range kaliqcda Oven Repair (including Ranges and Cooktops) 0 10-22-2008 06:29 PM
Replacing Dual Infinite Switch on Range juchunk Oven Repair (including Ranges and Cooktops) 0 05-02-2008 08:51 AM
