Discuss
stove top works, oven does not
 in
A couple weeks ago, our broiler and baker stopped working, even though the stove top burners work just fine. I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » stove top works, oven does not
  #1 (permalink)
Old 12-14-2009, 01:24 PM
Junior Member
Neddster is on a distinguished road
Default stove top works, oven does not
Model Number: MGR445IBDB   Brand: Maytag   Age: 1 - 5 years
A couple weeks ago, our broiler and baker stopped working, even though the stove top burners work just fine. I talked to my brother who is a public school engineer and he said I probably had a bad igniter. I ordered an igniter online, replaced it last week, the oven went on for like 9 minutes, then stopped and hasn't worked since. Prior to the first igniter completely going out, the broiler and baker would randomly work - sometimes for a whole cooking time setting, sometime for a partial setting. There was no rhyme or reason to it. I was told this igniter might be defective since there was a white spot on the back of the igniter (on the groove of the white portion of the igniter. I was told not to touch the sensitive heating element in the igniter as that would cause the spot, however, I never touched it.
Along with the igniter going out, the digital clock was moving slower than normal for regular timekeeping but almost normal for cooking time, even though the baker or broiler did not light. No error codes appeared at any time and it was obviously not on a sabbath time setting.
A contact online told me I might have to replace the clock or clockboard, whatever that is. He said the igniter might still work if the clock/clockboard is replaced but that it might be wise to get both another igniter and a clock/clockboard just to be on the safe side.
My question is this - does the slowness of the clock display have anything to do with the broiler or baker not working? If you think this needs replacing as well, how would I go about it and also, what would this part properly be called? Also, would there be a different part than what I named that could be the culprit? We bought this stove in June of "07 and were stunned that we would experience a malfunction of this appliance so quickly.
Thanks for any advice you can provide.
Ads By Google
Related Models
Maytag MGR4770ADH Range - F/s Std Gas
Maytag MGR4770ADL Range - F/s Std Gas
Maytag MGR4770ADW Range - F/s Std Gas
Maytag MGR5510ADH Range - S/c F/s Gas
Maytag MGR5510ADL Range - S/c F/s Gas
Maytag MGR5510ADW Range - S/c F/s Gas
Maytag MGR5710ADQ Range - S/c F/s Gas
Maytag MGR5710ADW Range - S/c F/s Gas
Maytag MGR5720ADH Range - S/c F/s Gas
Maytag MGR5720ADL Range - S/c F/s Gas
Maytag MGR5720ADT Range - S/c F/s Gas
Maytag MGR5720ADW Range - S/c F/s Gas
Maytag MGR5720BDQ Range - S/c F/s Gas
Maytag MGR5720BDW Range - S/c F/s Gas
Maytag MGR5721BDQ Range - S/c F/s Gas
Maytag MGR5721BDW Range - S/c F/s Gas
Maytag MGR5729ADA Range - S/c F/s Gas
Maytag MGR5729ADH Range - S/c F/s Gas
Maytag MGR5729ADL Range - S/c F/s Gas
Maytag MGR5729ADQ Range - S/c F/s Gas
Maytag MGR5729ADT Range - S/c F/s Gas
Maytag MGR5729ADW Range - S/c F/s Gas
Maytag MGR5730ADA Range - S/c F/s Gas
Maytag MGR5730ADH Range - S/c F/s Gas
Maytag MGR5730ADQ Range - S/c F/s Gas
Maytag MGR5730ADW Range - S/c F/s Gas
Maytag MGR5730BDB Range - S/c F/s Gas
Maytag MGR5730BDQ Range - S/c F/s Gas
Maytag MGR5730BDW Range - S/c F/s Gas
Maytag MGR5745ADA Range - S/c F/s Gas
Maytag MGR5745ADB Range - S/c F/s Gas
Maytag MGR5745ADW Range - S/c F/s Gas
Maytag MGR5750ADA Range - S/c F/s Gas
Maytag MGR5750ADH Range - S/c F/s Gas
Maytag MGR5750ADQ Range - S/c F/s Gas
Maytag MGR5750ADW Range - S/c F/s Gas
Maytag MGR5750BDB Range - S/c F/s Gas
Maytag MGR5750BDQ Range - S/c F/s Gas
Maytag MGR5750BDW Range - S/c F/s Gas
Maytag MGR5751ADB Range - S/c F/s Gas
Maytag MGR5751ADQ Range - S/c F/s Gas
Maytag MGR5751ADS Range - S/c F/s Gas
Maytag MGR5751ADW Range - S/c F/s Gas
Maytag MGR5751BDB Range - S/c F/s Gas
Maytag MGR5751BDQ Range - S/c F/s Gas
Maytag MGR5751BDS Range - S/c F/s Gas
Maytag MGR5751BDW Range - S/c F/s Gas
Maytag MGR5752ADB Range - S/c F/s Gas
Maytag MGR5752ADQ Range - S/c F/s Gas
Maytag MGR5752ADS Range - S/c F/s Gas
Maytag MGR5752ADW Range - S/c F/s Gas
Maytag MGR5752BDB Range - S/c F/s Gas
Maytag MGR5752BDQ Range - S/c F/s Gas
Maytag MGR5752BDS Range - S/c F/s Gas
Maytag MGR5752BDW Range - S/c F/s Gas
Maytag MGR5754QDQ Range - S/c F/s Gas
Maytag MGR5754QDS Range - S/c F/s Gas
Maytag MGR5754QDW Range - S/c F/s Gas
Maytag MGR5755ADB Range - S/c F/s Gas
Maytag MGR5755ADQ Range - S/c F/s Gas
Maytag MGR5755ADW Range - S/c F/s Gas
Maytag MGR5755BDB Range - S/c F/s Gas
Maytag MGR5755BDQ Range - S/c F/s Gas
Maytag MGR5755BDW Range - S/c F/s Gas
Maytag MGR5755QDB Range - S/c F/s Gas
Maytag MGR5755QDQ Range - S/c F/s Gas
Maytag MGR5755QDS Range - S/c F/s Gas
Maytag MGR5755QDW Range - S/c F/s Gas
Maytag MGR5765QDB Range - S/c F/s Gas
Maytag MGR5765QDQ Range - S/c F/s Gas
Maytag MGR5765QDS Range - S/c F/s Gas
Maytag MGR5765QDW Range - S/c F/s Gas
Maytag MGR5770ADA Range - S/c F/s Gas
Maytag MGR5770ADB Range - S/c F/s Gas
Maytag MGR5770ADQ Range - S/c F/s Gas
Maytag MGR5770ADW Range - S/c F/s Gas
Maytag MGR5770BDB Range - S/c F/s Gas
Maytag MGR5770BDQ Range - S/c F/s Gas
Maytag MGR5770BDW Range - S/c F/s Gas
Maytag MGR5775ADB Range - S/c F/s Gas
Maytag MGR5775ADQ Range - S/c F/s Gas
Maytag MGR5775ADW Range - S/c F/s Gas
Maytag MGR5775QDB Range - S/c F/s Gas
Maytag MGR5775QDQ Range - S/c F/s Gas
Maytag MGR5775QDS Range - S/c F/s Gas
Maytag MGR5775QDW Range - S/c F/s Gas
Maytag MGR5780BDB Range - S/c F/s Gas
Maytag MGR5780BDQ Range - S/c F/s Gas
Maytag MGR5780BDS Range - S/c F/s Gas
Maytag MGR5780BDW Range - S/c F/s Gas
Maytag MGR5870ADA Range - S/c F/s Gas
Maytag MGR5870ADB Range - S/c F/s Gas
Maytag MGR5870ADQ Range - S/c F/s Gas
Maytag MGR5870ADW Range - S/c F/s Gas
Maytag MGR5870BDB Range - S/c F/s Gas
Maytag MGR5870BDQ Range - S/c F/s Gas
Maytag MGR5870BDW Range - S/c F/s Gas
Maytag MGR5875QDB Range - S/c F/s Gas
Maytag MGR5875QDQ Range - S/c F/s Gas
Maytag MGR5875QDS Range - S/c F/s Gas
Maytag MGR5875QDW Range - S/c F/s Gas
Maytag MGR5880BDB Range - S/c F/s Gas
Maytag MGR5880BDQ Range - S/c F/s Gas
Maytag MGR5880BDS Range - S/c F/s Gas
Maytag MGR5880BDW Range - S/c F/s Gas
Maytag MGR6751BDB Freestanding - Double Oven - Gas
Maytag MGR6751BDS Freestanding - Double Oven - Gas
Maytag MGR6751BDW Freestanding - Double Oven - Gas
Maytag MGR6772BDB Freestanding - Double Oven - Gas
Maytag MGR6772BDQ Freestanding - Double Oven - Gas
Maytag MGR6772BDS Freestanding - Double Oven - Gas
Maytag MGR6772BDW Freestanding - Double Oven - Gas
Maytag MGR6775ADB Freestanding - Double Oven - Gas
Maytag MGR6775ADQ Freestanding - Double Oven - Gas
Maytag MGR6775ADS Freestanding - Double Oven - Gas
Maytag MGR6775ADW Freestanding - Double Oven - Gas
Maytag MGR6775BDB Freestanding - Double Oven - Gas
Maytag MGR6775BDB13 30" Gas Freestanding Self Clean Range Sealed Burner
Maytag MGR6775BDQ Freestanding - Double Oven - Gas
Maytag MGR6775BDQ13 30" Gas Freestanding Self Clean Range Sealed Burner
  #2 (permalink)
Old 12-14-2009, 03:22 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Unplug the igniter and check for 120VAC to the igniter (at the plug) while the control calls for Bake.
If there is proper voltage, the igniter is the culprit.
If there is no proper voltage, disconnect wires from the gas safety valve terminals (#9 on the diagram) and check for continuity between these terminals.
If there is continuity, replace the control board (aka a clock).
If there is no continuity, replace the gas safety valve.
- The igniter Part number: AP4096256
- The control board Part number: AP4397197
- The gas safety valve Part number: AP4097904
Here are the breakdown diagrams and Replacement parts for MAYTAG MGR4451BDB Range - F/s Std Gas | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-15-2009, 12:52 PM
Junior Member
Hi, Gene:
Thank you very much for your prompt reply. I truly appreciate it. I feel like a dunce but would you be so kind to explain how to do what you said.
  1. You say to unplug the igniter and check for 120 VAC to the igniter while the control calls for Bake. So what do I do? I'm guessing you mean to set the oven to Bake, meaning the stove is still plugged into the electrical circuit while I inspect. Assuming I do that, how do I check for 120 VAC with the igniter unplugged? Where do I look?
  2. You say that if there is no proper voltage, to disconnect the wires from the gas safety valve terminals. I think I know where that's at, thanks in part to the diagram. But how do you define continuity in this sense? What determines continuity?
Thanks again for your anticipated assistance.
Nedd
  #4 (permalink)
Old 12-15-2009, 01:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You have to have a simple multimeter to perform these tests.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
In the first post you said: "I ordered an igniter online, replaced it last week".
My question is: how did you do it?
__________________
  #5 (permalink)
Old 12-15-2009, 02:25 PM
Junior Member
Hi, Gene:
My brother, who is the chief engineer at the school he works at, told me over the phone when I told him what occurred that it was probably the igniter (or as he called it, the hot surface igniter) that likely caused the problem. He told me how to access it, look it over and where I could get one online. I was able to remove the broiler cover, then the spreader and was able to remove the old igniter. My guess is that the old igniter may have been bad as one of the inside wires apparently caused the outside wire to become loose. However, when I got the new one thru the mail and installed it (fairly easy to do), the oven worked for about 9 minutes and then went out, never since to return. Installation of this was easy.
As far as a multimeter goes, I'll have to look it up and figure how and where to get one. I guess that means I'll have to get this before anything can be done. Thanks for that link as well, very helpful.
Never mind, I saw the link where to get that device. Thanks.
Nedd
Last edited by Neddster : 12-15-2009 at 02:26 PM. Reason: Updated info, forgot to add one item
  #6 (permalink)
Old 12-15-2009, 02:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Nedd,
Let us know when you ready to proceed further.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Stove works, oven doesn't cchun Oven Repair (including Ranges and Cooktops) 0 01-15-2010 01:30 PM
stove works, oven doesn't csteck4 Oven Repair (including Ranges and Cooktops) 0 12-31-2009 08:57 AM
Oven will not turn on, broiler works, stove top works caewart Oven Repair (including Ranges and Cooktops) 1 06-20-2009 05:25 AM
Kenmore Range - Stove works, Oven Doesn't daranj Oven Repair (including Ranges and Cooktops) 0 03-21-2008 07:42 PM
GE oven stove top works, ignitor works, no gas flow in oven mikeburton@cableone.net Oven Repair (including Ranges and Cooktops) 1 12-26-2007 07:09 PM
