| » No display on control pad after cleaning |
Model Number: MGR5730BDW Brand: Maytag Age: 5 - 10 years
Hi:
I cleaned my LP gasMaytag oven last night and now there is nothing reading on the control pad and none of the touch buttons work. What is wrong and how do I fix it? The stove burners & igniters for same, light in the oven work fine. Have already tried turning the power off to the stove but that did nothing for the control pad. Occasionally the time comes up, flashing 12:00 but when I hit any of the touch pads, 12:00 disappears. Have also tried holding down both the clock pad and the cancel pad at the same time for 5 seconds as recommended by the guy at the Maytag service centre but that did nothing either. Marg Ads By Google Related Models |
Marg,
Most likely the problem is a bad control board (aka a clock). - The control board Part number: AP4428977 Here are the breakdown diagrams and Control panel replacement parts for MAYTAG MGR5730BDW Range - S/c F/s Gas | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
You are welcome, Marg. Keep us posted.
__________________
Quote:
As it turned out, it's a loose wire somewhere in the wiring of the stove, not the control panel itself that is the problem. Discovered this when we moved the stove a little bit and up popped the control panel display! Have no idea where the wiring is loose as we're just keeping our fingers crossed that it continues to work as a repair guy wanted a small fortune to come out to our place in the country to try to find which wire it is. If it gives up the ghost again, we'll have to get someone out here but in the meantime, we're just using the stove and trying not to jar it!! Best of Luck with yours, Marg |
| Display Modes | |
| self cleaning "door" display on control panel | japdx | Oven Repair (including Ranges and Cooktops) | 0 | 10-19-2009 09:22 AM |
| control pannel dead after cleaning | RichardR | Oven Repair (including Ranges and Cooktops) | 1 | 08-26-2009 01:36 PM |
| Clock/timer Display Meltdown While Self Cleaning Oven | WANAGO | Oven Repair (including Ranges and Cooktops) | 1 | 05-14-2009 04:05 PM |
| Control display dim . | ft52 | Oven Repair (including Ranges and Cooktops) | 0 | 04-13-2009 12:05 PM |
| control board display on | phillip melton | Oven Repair (including Ranges and Cooktops) | 3 | 02-18-2008 04:25 PM |
