Discuss
Dacor Epicure wall oven error code L-34 Temp sensor
 in
My double wall oven model EO230 dual Convection has a error code L-34 Temp Sensor. I can't find the code
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Dacor Epicure wall oven error code L-34 Temp sensor
  #1 (permalink)
Old 12-14-2009, 09:38 AM
HDK HDK is offline
Junior Member
HDK is on a distinguished road
Default Dacor Epicure wall oven error code L-34 Temp sensor
Brand: -brand-   Age: Less than 1 year
My double wall oven model EO230 dual Convection has a error code L-34 Temp Sensor. I can't find the code anywhere. The listed codes are all F-codes. Do i just need to replace the Temp sensor probe in the oven? Can you give me any help?
  #2 (permalink)
Old 12-14-2009, 07:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
"L34 Temp sensor lower oven" means the control senses open temperature sensor for the lower oven.
Remove the oven from the cabinet and measure the oven sensor resistance at the sensor plug behind the rear cover. It suppose to be about 1100 Ohms at the room temperature.
If the reading is wrong, replace the sensor.
If the reading at the plug is correct, check it at the control board plug. If the reading is still correct, replace the control panel assembly.
- The oven sensor Part number: AP3887956
- The control panel assembly Part number: AP3886849
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-15-2009, 04:58 PM
HDK HDK is offline
Junior Member
Default
Thanks for the help, I'll check it out.
HDK
  #4 (permalink)
Old 12-15-2009, 05:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #5 (permalink)
Old 12-16-2009, 05:15 PM
HDK HDK is offline
Junior Member
Default
Gene, I am able to pull the sensor out from inside the oven without removing the oven from the wall. Is this a bad idea? I can get to the plug connection, although the contacts in the plug are too small for my multimeter, I guess I can improvise a method to test with small wire.
HDK
  #6 (permalink)
Old 12-16-2009, 05:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I did recommend to test it from the back because the problem can be a bad wire plug or harness. It is a good idea to eliminate the sensor plug at all and reconnect the wires using a high temperature porcelain wire nuts.
__________________
  #7 (permalink)
Old 12-17-2009, 01:11 PM
HDK HDK is offline
Junior Member
Default
Thanks Gene, that's what I'll do.
  #8 (permalink)
Old 12-19-2009, 07:06 AM
HDK HDK is offline
Junior Member
Default
Gene, I tested the temp sensors and the resistance seemed to check out right. However, when I reinstalled the sensors, I switched the upper and lower sensors and now the error code says u32 instead of L34. Does this mean that now that i switched the sensors, the oven senses the upper sensor is bad? (the one that was in the lower oven). Therefore am I correct in assuming that I just need a new sensor to replace the bad one?
HDK
BTW, thanks for all your help.
  #9 (permalink)
Old 12-21-2009, 05:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
"U32" means "open upper oven sensor". Most likely there is a poor connection. Double check everything.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
duet washer replacing ntc sensor F05 error code artie1968 Washer Repair 1 11-16-2010 11:45 AM
Dacor Epicure raised ventilation TJZ Oven Repair (including Ranges and Cooktops) 1 11-29-2009 04:09 AM
Maytag Wall Oven Error Code AmandaWest Washer Repair 1 11-17-2009 02:30 PM
Dacor Epicure Duel Fuel Range Problems Harvey@houseworksinc.com Oven Repair (including Ranges and Cooktops) 0 01-01-2009 11:22 AM
Temp sensor error 4 andrewcater Microwave Repair 0 04-28-2008 09:01 AM
