| » Broiler not working |
Model Number: SC301T Brand: Thermador Age: 5 - 10 years
Broiler not heating, display says it is on. Bake ok. Checked continuity of broiler element~16ohms. Have 230v across contacts of broil relay when broil selected. Relay contacts obviously not closing.Suspect bad relay board?
That would also be my guess. I cannot find a wiring diagram for this unit so cannot be of much use here. Would be nice to confirm it. If you measure a voltage across the relay coil and it does not close then you know for sure that it is toast. I am not sure what that voltage should be. Could be that the relay coil has opened which would be an easier check. Or perhaps you can hear the relay close, then you would know that it's contacts are shot. Depending on which board is gone it may be difficult to find a replacement.
__________________
There are companies out there that will repair boards.
I have never used one so cannot recommend one to you. Also I do not know what they charge. Just Google "oven timer control board repair"
__________________
| Display Modes | |
| Whirlpool Broiler Not Working | dvdb | Oven Repair (including Ranges and Cooktops) | 8 | 03-15-2012 11:05 AM |
| Whirlpool Broiler not working | formula2fast | Oven Repair (including Ranges and Cooktops) | 3 | 01-02-2011 08:20 PM |
| Broiler Not Working | raulrio | Oven Repair (including Ranges and Cooktops) | 5 | 11-24-2009 01:06 PM |
| broiler not working | RMoore | Oven Repair (including Ranges and Cooktops) | 2 | 01-28-2009 03:04 PM |
| Oven nor broiler is working | greg1 | Oven Repair (including Ranges and Cooktops) | 3 | 11-21-2008 07:43 AM |
