Discuss
Trying to repair a GE Stovetop
 in
I'm trying to replace the igniter switches on my GE Stovetop but have no drawings to go by. I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Trying to repair a GE Stovetop
  #1 (permalink)
Old 03-17-2008, 05:31 PM
panderson@identitysystems panderson@identitysystems is offline
Junior Member
panderson@identitysystems is on a distinguished road
Default Trying to repair a GE Stovetop
Model Number: JGP932BECBB   Brand: GE   Age: 1 - 5 years
I'm trying to replace the igniter switches on my GE Stovetop but have no drawings to go by. I can't even figure out how to open the unit to get to the switches. Don't want to randomly start removing screws. Any suggestings/help?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-18-2008, 04:21 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
In order to access the ignition switches you have to remove all burners and the top panel.
- The part number for the ignition switches assembly is AP3185909
Here are the break down diagrams for the GE stove Model JGP932BEC1BB
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-18-2008, 09:07 PM
Junior Member
Default
Thanks for the info. One other question. I see that the burners have 2 screws each but are also held down by the igniters. How do you remove the igniters(#154 in the drawing)?
  #4 (permalink)
Old 03-26-2008, 09:26 AM
Junior Member
Default
Part #AP3185909 (WB18T10176) isn't the correct part. Attached is one of the switches from the existing harness. I guess I'll be contacting GE directly to see if there is a recall. I have had continous problems with this unit almost from the beginning. Why they would have a non-waterproof switch virtually exposed to the cooking surface is beyond me!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Stovetop spark module not working GrahamB2580 Oven Repair (including Ranges and Cooktops) 23 09-17-2008 04:08 PM
stovetop and oven ignighters do not work tbone43 Oven Repair (including Ranges and Cooktops) 1 03-07-2008 08:33 PM
Stovetop burner will not heat ellist Oven Repair (including Ranges and Cooktops) 3 01-06-2008 09:02 AM
Maytag stovetop igniter help! steve1966 Oven Repair (including Ranges and Cooktops) 0 01-02-2008 11:51 AM
GE Glass Stovetop lil_nicky Oven Repair (including Ranges and Cooktops) 1 08-28-2007 10:15 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
