Discuss
replacement spark module #WPL 12001596
 in
DEAR SIR; I OWN A STOVETOP MODEL # LGT451 02 BRAND NAME MODERNMAID ; I RECENTLY ORDERED A SPARKMODULE AND FOUR SPARK
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » replacement spark module #Whirlpool 12001596
  #1 (permalink)
Old 03-17-2008, 11:00 AM
ramsing ramsing is offline
Junior Member
ramsing is on a distinguished road
Default replacement spark module #Whirlpool 12001596
Model Number: LGT45102   Brand: Modern Maid   Age: More than 10 years
DEAR SIR;
I OWN A STOVETOP MODEL # LGT451 02 BRAND NAME MODERNMAID ; I RECENTLY ORDERED A SPARKMODULE AND FOUR SPARK SWITCHES FOR THIS APPLIANCE, THE SALESMAN TOLD ME THE PARTS FOR THIS MODEL NUMBER IS NO LONGER AVAILABLE; AS THE MODEL NUMBER DOES NOT COME UP ON HIS LISTING HOWEVER THERE IS A MAYTAG SWITCH PART # Y0042053 WHICH IS A DIRECT REPLACEMENT AND WILL WORK ; THE SPARK MODULE IS ALSO NO LONGER AVAILABLE BUT MAYTAG PART NUMBER 16009514 OR APPLIANCE PARTSPROS PART NUMBER Whirlpool 12001596 WILL WORK AND IS A DIRECT REPLACEMENT . WHEN THE SPARK MODULE ARRIVE I COMPARE THE QUANTITY OF TERMINALS BETWEEN THE REPLACEMENT AND THE ORIGINAL FROM THE STOVE; I NOTICE THE RECOMMENDED REPLACEMENT CARRIES FOUR OUTPUT TERMINALS; AND THE ORIGINAL MODULE FROM THE STOVE CARRIES ONLY TWO OUTPUT TERMINALS ; MY QUESTION IS. WILL THE REPLACEMENT MODULE WORK EVEN THOUGH IT CARRIES FOUR OUTPUT TERMINALS INSTEAD OF TWO ?
ALSO, WHAT WILL HAPPEN IF THE A/C POWER CORD GROUND WIRE TO THE STOVE METAL FRAMEWORK IS NOT CONTINOUS.
THE STOVE CARRIES ONLY TWO SPARK ELECTRODES ,ONE LIGHTS UP TWO BURNERS ON ONE SIDE AND THE OTHER LIGHTS UP THE OTHER TWO , THE RECOMMENDED MODULE APPEARS AS IF IT WAS DESIGNED TO FIRE UP FOUR ELECTRODES INSTEAD OF TWO. IF THE REPLACEMENT MODULE WILL WORK WHAT ARE THE ADVANTAGES PLEASE ASSIST WITH ADVISE OR RECOMMENDATIONS.
THANK YOU
RAMSING
Related Models
Whirlpool LGT5434AN0
Whirlpool LGT5434AQ0
Whirlpool LGT5434AW0
Whirlpool LGT5436AN0
Whirlpool LGT5436AW0
Whirlpool LGT5624BN0
Whirlpool LGT5624BN1
Whirlpool LGT5624BN2
Whirlpool LGT5624BQ0
Whirlpool LGT5624BQ1
Whirlpool LGT5624BQ2
Whirlpool LGT5624BW0
Whirlpool LGT5624BW1
Whirlpool LGT5624BW2
Whirlpool LGT5624DQ0
Whirlpool LGT5624DQ1
Whirlpool LGT6634AN0
Whirlpool LGT6634AN1
Whirlpool LGT6634AN2
Whirlpool LGT6634AQ0
Whirlpool LGT6634AQ1
Whirlpool LGT6634AQ2
Whirlpool LGT6634AW0
Whirlpool LGT6634AW1
Whirlpool LGT6634AW2
Whirlpool LGT6634DQ0
Whirlpool LGT6634DQ1
Whirlpool LGT6634DZ0
Whirlpool LGT6634DZ1
Whirlpool LGT6638AN0
Whirlpool LGT6638AN1
Whirlpool LGT6638AN2
Whirlpool LGT6638AQ0
Whirlpool LGT6638AQ2
Whirlpool LGT6638AW0
Whirlpool LGT6638AW1
Whirlpool LGT6638AW2
Whirlpool LGT6638DQ0
Whirlpool LGT6638DQ1
Whirlpool LGT6638DZ0
Whirlpool LGT6638DZ1
Whirlpool LGT7646AN0
Whirlpool LGT7646AQ0
Whirlpool LGT7646AQ2
Whirlpool LGT7646AW0
Whirlpool LGT7646AZ0
Whirlpool LGT7646AZ2
Whirlpool LGT7646DQ0
Whirlpool LGT7646DQ1
Whirlpool LGT7646DZ0
Whirlpool LGT7646DZ1
Whirlpool LGT7646EQ0
Whirlpool LGT7646EQ1
Whirlpool LGT7646EQ2
Whirlpool LGT7646EQ3
Whirlpool LGT7646EZ0
Whirlpool LGT7646EZ1
Whirlpool LGT7646EZ2
Whirlpool LGT7646EZ3
Whirlpool LGT7848AN0
Whirlpool LGT7848AQ0
Whirlpool LGT7848AQ1
Whirlpool LGT7848AQ2
Whirlpool LGT7848AW0
Whirlpool LGT7848AZ0
Whirlpool LGT7848AZ1
Whirlpool LGT7848AZ2
Whirlpool LGT7848DQ0
Whirlpool LGT7848DQ1
Whirlpool LGT7848DZ0
Whirlpool LGT7848DZ1
Whirlpool LGT8858AN0
Whirlpool LGT8858AN1
Whirlpool LGT8858AN2
Whirlpool LGT8858AQ0
Whirlpool LGT8858AQ1
Whirlpool LGT8858AQ2
Whirlpool LGT8858AW0
Whirlpool LGT8858AW1
Whirlpool LGT8858AW2
Whirlpool LGT8858AZ0
Whirlpool LGT8858AZ1
Whirlpool LGT8858AZ2
Whirlpool LGT8858DQ0
Whirlpool LGT8858DQ1
Whirlpool LGT8858DZ0
Whirlpool LGT8858DZ1
Whirlpool LGV4434AN0
Whirlpool LGV4434AW0
Whirlpool LGV4436AN0
Whirlpool LGV4436AW0
Whirlpool LGV4624BG0
Whirlpool LGV4624BN0
Whirlpool LGV4624BW0
Whirlpool LGV4634JQ0
Whirlpool LGV4634JQ1
Whirlpool LGV4634JQ2
Whirlpool LGV4634JQ3 29" Gas Dryer
Whirlpool LGV4634JT0
Whirlpool LGV4634JT1
Whirlpool LGV4634JT2
Whirlpool LGV4634PQ0 29" Gas Dryer
Whirlpool LGV4634PQ1 29" Gas Dryer
Whirlpool LGV5634AG0
Whirlpool LGV5634AN0
Whirlpool LGV5634AW0
Whirlpool LGV5638AN0
Whirlpool LGV5638AW0
Whirlpool LGV5644AN0
Whirlpool LGV5644AW0
Whirlpool LGV6634BN0
Whirlpool LGV6634BN1
Whirlpool LGV6634BN2
Whirlpool LGV6634BQ0
Whirlpool LGV6634BQ1
Whirlpool LGV6634BQ2
Whirlpool LGV6634BW0
Whirlpool LGV6634BW1
Whirlpool LGV6634BW2
Whirlpool LGV6634DQ0
  #2 (permalink)
Old 03-17-2008, 09:00 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Default
Hi Ramsing,
Looks like the spark module with the part number 12001596 is not what you need for your stove.
The spark module for your stove is one of most popular. It's made by many different manufacturers with different part numbers.
I found the best deal on this part. it's made by Frigidaire and the price is just $22.68
The spark module
- The Frigidaire part number 5303912606 is Appliance Parts Pros item number AP2149264
If you can post pictures of the original ignition switch, we probably can help you to find a right replacement too.
The power cord ground wire must be connected to the metal body of the stove. This is very important for proper performance of the spark module.
__________________
  #3 (permalink)
Old 03-20-2008, 12:39 PM
Junior Member
Default
hellow gene;
thanks for the reply; the spark module you recommended is here ; fridigare part # 5303912606 appliance parts pro part # ap2149264 .
upon opening the package , the installation instruction is showing that the # one output terminal has to be connected directly to ground , hence the reason why i beleive the short green ground strap included in the bag ; this leaves only the number 2 output terminal without a connection , where does the # 2 terminal from the module connects? if i were to connect one of the spark electrodes to the number two terminal , where do i connect the remaining spark electrode as the stove top carries two electrodes ; the drawing is also showing the numbers 5; 11; as the input , and the number 12 to ground and the number 13 goes to nowhere . all those numbers are enclosed in a circle on the drawing, what do they mean? its now very confusing , as to why the green wire is connecting the number one output terminal to ground and it does not say where the number two output terminal is supposed to be connected;
the output side of the drawing is very confusing; where do i connect the two spark electrodes on to the module ? if they are connected to the module output #1 and #2 terminals where do i connect the ground wire which is supplied with the package . ???????? please refer to my first letter that i sent to you ; also refer to the installation tructions that comes with the module , please let me know .
thank you
ramsing
  #4 (permalink)
Old 03-20-2008, 02:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Ramsing,
You have to use the green wire only if there is just one output used.
There are four terminals on the spark module - two input ("L" - lane & "N" - neutral) and two output. Does not matter which one to which igniters (electrodes) connected.
__________________
  #5 (permalink)
Old 03-21-2008, 10:04 AM
Junior Member
Default
hellow jean;
thank you very kindly for the information.
yours respectfully
ramsing
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Stovetop spark module not working GrahamB2580 Oven Repair (including Ranges and Cooktops) 27 08-24-2009 09:19 AM
control module replacement shop Dishwasher Repair 1 08-23-2009 06:54 PM
where is the spark module located dodgeguy Oven Repair (including Ranges and Cooktops) 3 01-26-2008 08:25 AM
Spark switch replacement Boris Oven Repair (including Ranges and Cooktops) 2 12-31-2007 04:09 PM
spark module replacement Mike R. Oven Repair (including Ranges and Cooktops) 0 11-12-2007 02:35 PM
