Discuss
clock panel goes out;error code;short in oven light
 in
Clock panel is blank. Turn on top burner or play with oven light switch and panel display comes on. Push
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » clock panel goes out;error code;short in oven light
  #1 (permalink)
Old 12-11-2009, 10:05 PM
Junior Member
jedward33 is on a distinguished road
Default clock panel goes out;error code;short in oven light
Model Number: FES365EBD   Brand: Frigidaire   Age: 1 - 5 years
Clock panel is blank. Turn on top burner or play with oven light switch and panel display comes on. Push 'bake', it beeps and shows a F30 code. Turn on oven light switch and panel goes blank. Technician replaced clock panel - no change. Techn claims it is my house wiring. Yet, top burners work fine. Yet, when you play with the oven light switch the panel comes on and all buttons work. Just no bake, and turning the oven lite swt on shuts everything down. Can there be a short in the oven light circuit?
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 12-12-2009, 05:49 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Cover replacement parts for FRIGIDAIRE FES365EBD Frigidaire/electric Range | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodin.../318271958.pdf
Here is a sheet I found on error codes.
http://frigidaireservicetips.com/pdf...ndRTDchart.pdf
I doubt it would be a short as this should blow the breaker.
More likely an open with something else contributing to the problem.
Could be you are feeding bach through earth grond instead of Neutral.
You are somehow supplying Neutral or power to the control board through the fan switch and/or the stove top elements.
I would check the power to the unit just so it can be eliminated as a possible cause. Do not understand why the service tech did not do this.
L1 to L2 should be 240 volts odds are high this is OK as the stove top elements work.
Check with and without the unit connected.
If this is a 3 wire hook up I would check that the ground strap from Neutral to the units frame is OK. Also check all connections at the units terminal strip.
If the above is OK disconnect the light switch, to see if it now operates correctly.
If no change
Disconnect the temperature probe. F30 is a temp probe error so could be it is doing something weird like shorting to the frame internally.
Note with it disconnected you will not get any heat as the unit will think that it is over temperature.
__________________
  #3 (permalink)
Old 12-16-2009, 12:28 PM
Junior Member
Default
Verified the incoming voltage @ 120VAC on legs and 240 total. However when you plug the oven ac cord in, you see the first problem. Checking voltage at the 1st terminal where the AC cord is connected, you get 240VAC between Neutral and one leg and very low voltage on the other leg. Both the oven light and the oven temp probe have been disconnected with no change. The service tech has now been to my house a total of 3 times and left without any idea of the problem. To repeat, the clock panel is blank; turn on any top heating unit, wait for the hot surface lamp to come on, then the panel lights up. Open the door or turn on the oven lamp and clock panel goes out. Any more suggestions? Thanks.
  #4 (permalink)
Old 12-17-2009, 04:58 AM
Senior Expert
APP Volunteer
Default
Just a couple questions.
Did this unit work here in the past?
Has anything been done recently with the wiring to this unit?
Is this a 3 wire or 4 wire connection?
What are the voltages at the terminal strip when the panel is working?
Something is very, very strange.
You should not be able to measure 240 volts when referenced to Neutral or ground. It can only be between L1 to L2.
Do not know how much you know about electricity but here s how it works.
Note the explanation is not strictly true but will do to explain this.
You have two 120 volt AC lines coming into the house and they share a common Neutral and they are 180 degrees out of phase.
So when one is at positive 120 volts, the other is at negative 120 volts when referenced to the common Neutral.
When referenced to each other then you have 240 volts.
So I would have to say that it sounds like the stove/line cord is wired up incorrectly as that is the only way I can think of for you to measure 240 volts from the center connector on the strip (Neutral) to either of the other terminals.
I would remove the cord from the unit and check it with a meter.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Air F5 error code - "Clock" or Power relay board? chanpaul Oven Repair (including Ranges and Cooktops) 2 12-08-2009 12:22 PM
Oven/clock Control Panel is no longer lit but oven does heat. jthomas@abrakadoodle.com Oven Repair (including Ranges and Cooktops) 1 12-05-2009 04:07 PM
clock/oven panel don't work frederic Oven Repair (including Ranges and Cooktops) 0 11-10-2009 12:44 PM
Whirlpool Oven shows Error Code E0F2 on Panel cool66 Oven Repair (including Ranges and Cooktops) 0 05-01-2009 04:54 PM
F2 code on oven/clock panel Bluecrab Oven Repair (including Ranges and Cooktops) 3 02-18-2009 04:08 PM
