| » Double Oven Problem |
Model Number: rbd305pdq12 Brand: Whirlpool Age: 5 - 10 years
Hello.
My upper oven does not heat properly. The broiler works fine but the baking element is around 200@350. I replaced the element and found one of the pins arced off the wire. I did a resistance check on the temp sensor and it is 1.1k ohms. Is there anything else left to try or is the brain fried? Thank you, Al Ads By Google Related Models |
Replacement parts for WHIRLPOOL RBD305PDQ12 | AppliancePartsPros.com Here is the wiring diagram http://www.servicematters.com/docs/w...%208301761.pdf I assume that the bake element is still not heating up. I would double check the wiring from the control board to the bake element. If OK then odds are high that it is the board. Probably blew the bake relay contacts up when it arced.
__________________
| Display Modes | |
| Magic Chef Double Oven Upper oven not working | scri8e | Oven Repair (including Ranges and Cooktops) | 18 | 12-30-2012 04:50 PM |
| GE double stack oven problem | Duane Hari | Oven Repair (including Ranges and Cooktops) | 0 | 11-10-2009 09:47 PM |
| Whirlpool Double Range Control Panel Problem | Title Man | Oven Repair (including Ranges and Cooktops) | 2 | 10-05-2009 09:14 AM |
| F1/F7 problem with Jenn Air double oven | Fish Head | Oven Repair (including Ranges and Cooktops) | 1 | 09-29-2009 10:12 AM |
| Old Roper Built-In Double Ovens heating problem | ms03028 | Oven Repair (including Ranges and Cooktops) | 1 | 01-09-2009 01:30 PM |
