Discuss
magic chef / maytag made oven will not heat - 4 stovetop burners work fine
 in
Hello, My oven will not heat on my Magic Chef range. I don't smell gas and I don't know where
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » magic chef / maytag made oven will not heat - 4 stovetop burners work fine
  #1 (permalink)
Old 12-09-2009, 03:10 PM
Junior Member
hellotracy is on a distinguished road
Default magic chef / maytag made oven will not heat - 4 stovetop burners work fine
Model Number: 31003SAW   Brand: Magic Chef   Age: Less than 1 year
Hello,
My oven will not heat on my Magic Chef range. I don't smell gas and I don't know where the pilot light would be, but I don't see anything lit.
The 4 burners on the range work just fine.
Any help or suggestions are appreciated!
Related Models
Magic Chef 31003SAW RANGE- F/S STD GAS
Magic Chef 3100PPA RANGE- F/S STD GAS
Magic Chef 3100PPA-K RANGE- F/S STD GAS
Magic Chef 3100PPW RANGE- F/S STD GAS
Magic Chef 3100PPW-K RANGE- F/S STD GAS
Magic Chef 3100PTA-K RANGE- F/S STD GAS
Magic Chef 3100PTW-K RANGE- F/S STD GAS
Magic Chef 3100PTW-KL RANGE- F/S STD GAS
Magic Chef 3100SPA RANGE- F/S STD GAS
Magic Chef 3100SPA-K RANGE- F/S STD GAS
Magic Chef 3100SPW RANGE- F/S STD GAS
Magic Chef 3100SPW-K RANGE- F/S STD GAS
Magic Chef 3100STA-K RANGE- F/S STD GAS
Magic Chef 3100STW-K RANGE- F/S STD GAS
Magic Chef 3101WPA RANGE- F/S STD GAS
Magic Chef 3101WPW RANGE- F/S STD GAS
Magic Chef 3101WTA RANGE- F/S STD GAS
Magic Chef 3101WTW RANGE- F/S STD GAS
Hoover 311
Magic Chef 31100KAA RANGE- F/S STD GAS
Magic Chef 31100KAW RANGE- F/S STD GAS
Magic Chef 31100PAA RANGE- F/S STD GAS
Magic Chef 31100PAW RANGE- F/S STD GAS
Magic Chef 31100SAA RANGE- F/S STD GAS
Magic Chef 31100SAW RANGE- F/S STD GAS
Magic Chef 31101PAA RANGE- F/S STD GAS
Magic Chef 31101PAW RANGE- F/S STD GAS
Magic Chef 3110KPA RANGE- F/S STD GAS
Magic Chef 3110KPA-K RANGE- F/S STD GAS
Magic Chef 3110KPW RANGE- F/S STD GAS
Magic Chef 3110KPW-K RANGE- F/S STD GAS
Magic Chef 3110KRA RANGE- F/S STD GAS
Magic Chef 3110KRW RANGE- F/S STD GAS
Magic Chef 3110KTA-K RANGE- F/S STD GAS
Magic Chef 3110KTW-K RANGE- F/S STD GAS
Magic Chef 3110PPA RANGE- F/S STD GAS
Magic Chef 3110PPA-K RANGE- F/S STD GAS
Magic Chef 3110PPW RANGE- F/S STD GAS
Magic Chef 3110PPW-K RANGE- F/S STD GAS
Magic Chef 3110PRA RANGE- F/S STD GAS
Magic Chef 3110PRA-K RANGE- F/S STD GAS
Magic Chef 3110PRV RANGE- F/S STD GAS
Magic Chef 3110PRV-K RANGE- F/S STD GAS
Magic Chef 3110PRW RANGE- F/S STD GAS
Magic Chef 3110PRW-K RANGE- F/S STD GAS
Magic Chef 3110PTA-K RANGE- F/S STD GAS
Magic Chef 3110PTV-K RANGE- F/S STD GAS
Magic Chef 3110PTW-K RANGE- F/S STD GAS
Magic Chef 3110PTW-KL RANGE- F/S STD GAS
Magic Chef 3115PUV RANGE- F/S STD GAS
Magic Chef 3116PRA RANGE- F/S STD GAS
Magic Chef 3116PRW RANGE- F/S STD GAS
Magic Chef 31203KAA RANGE- F/S STD GAS
Magic Chef 31203KAW RANGE- F/S STD GAS
Magic Chef 31203PAA RANGE- F/S STD GAS
Magic Chef 31203PAQ RANGE- F/S STD GAS
Magic Chef 31203PAV RANGE- F/S STD GAS
Magic Chef 31203SAA RANGE- F/S STD GAS
Magic Chef 31203SAW RANGE- F/S STD GAS
Magic Chef 31203WAA RANGE- F/S STD GAS
Magic Chef 31203WAW RANGE- F/S STD GAS
Magic Chef 3120SPA RANGE- F/S STD GAS
Magic Chef 3120SPW RANGE- F/S STD GAS
Magic Chef 3120SRA RANGE- F/S STD GAS
Magic Chef 3120SRW RANGE- F/S STD GAS
Magic Chef 31211SAA RANGE- F/S STD GAS
Magic Chef 31211SAW RANGE- F/S STD GAS
Magic Chef 31211WAA RANGE- F/S STD GAS
Magic Chef 31211WAM RANGE- F/S STD GAS
Magic Chef 31211WAV RANGE- F/S STD GAS
Magic Chef 31211WAW RANGE- F/S STD GAS
Magic Chef 31211XAA RANGE- F/S STD GAS
Magic Chef 31211XAS RANGE- F/S STD GAS
Magic Chef 31211XAW RANGE- F/S STD GAS
Magic Chef 31213SAA RANGE- F/S STD GAS
Magic Chef 31213SAW RANGE- F/S STD GAS
Magic Chef 31213WAA RANGE- F/S STD GAS
Magic Chef 31213WAM RANGE- F/S STD GAS
Magic Chef 31213WAV RANGE- F/S STD GAS
Magic Chef 31213WAW RANGE- F/S STD GAS
Magic Chef 31213XAA RANGE- F/S STD GAS
Magic Chef 31213XAW RANGE- F/S STD GAS
Magic Chef 3121SPA RANGE- F/S STD GAS
Magic Chef 3121SPW RANGE- F/S STD GAS
Magic Chef 3121SRA RANGE- F/S STD GAS
Magic Chef 3121SRW RANGE- F/S STD GAS
Magic Chef 3121STA RANGE- F/S STD GAS
Magic Chef 3121STW RANGE- F/S STD GAS
Magic Chef 3121WPA RANGE- F/S STD GAS
Magic Chef 3121WPV RANGE- F/S STD GAS
Magic Chef 3121WPW RANGE- F/S STD GAS
Magic Chef 3121WRA RANGE- F/S STD GAS
Magic Chef 3121WRV RANGE- F/S STD GAS
Magic Chef 3121WRW RANGE- F/S STD GAS
Magic Chef 3121WTA RANGE- F/S STD GAS
Magic Chef 3121WTV RANGE- F/S STD GAS
Magic Chef 3121WTW RANGE- F/S STD GAS
Magic Chef 3121XPA RANGE- F/S STD GAS
Magic Chef 3121XPS RANGE- F/S STD GAS
Magic Chef 3121XPW RANGE- F/S STD GAS
Magic Chef 3121XRA RANGE- F/S STD GAS
Magic Chef 3121XRA-UX RANGE- F/S STD GAS
Magic Chef 3121XRA-X RANGE- F/S STD GAS
Magic Chef 3121XRS RANGE- F/S STD GAS
Magic Chef 3121XRW RANGE- F/S STD GAS
Magic Chef 3121XRW-UX RANGE- F/S STD GAS
Magic Chef 3121XRW-X RANGE- F/S STD GAS
Magic Chef 3121XTA RANGE- F/S STD GAS
Magic Chef 3121XTS RANGE- F/S STD GAS
Magic Chef 3121XTW RANGE- F/S STD GAS
Magic Chef 3126SRA RANGE- F/S STD GAS
Magic Chef 3126SRW RANGE- F/S STD GAS
Magic Chef 3126STA RANGE- F/S STD GAS
Magic Chef 3126STW RANGE- F/S STD GAS
Magic Chef 3127STA RANGE- F/S STD GAS
Magic Chef 3127STW RANGE- F/S STD GAS
Magic Chef 3127WTA RANGE- F/S STD GAS
Magic Chef 3127WTV RANGE- F/S STD GAS
Magic Chef 3127WTW RANGE- F/S STD GAS
Magic Chef 3127XTA RANGE- F/S STD GAS
  #2 (permalink)
Old 12-09-2009, 07:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
There is a glow coil igniter in the oven. Remove the oven floor and the flame spreader to access the part. Unplug the igniter and check for 120 VAC to the igniter while the oven thermostat calls for heat.
If there is 120VAC, replace the igniter.
If there is no proper voltage, remove the wires from the safety valve (#18 on the diagram) and check for continuity between those terminals.
If there is no continuity, replace the gas safety valve.
If there is continuity, replace the oven thermostat.
- The oven igniter Part number: AP4012072
- The oven thermostat Part number: AP4092858
- The gas safety valve Part number: AP4092375
Here are the breakdown diagrams and Replacement parts for MAGIC CHEF 31003SAW Range - F/s Std Gas | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-22-2009, 08:51 AM
Junior Member
Default oven is working!
thanks so much for the info!
turns out, our oven is working, but it just takes a much longer time to get the flame going.
does this mean that one of our parts is on its way out? if so, which one, most likely?
  #4 (permalink)
Old 12-22-2009, 06:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If it takes more than 70 seconds to light the oven burner, then igniter is weak. It'll completely die pretty soon.
If it takes more than 90 second, it's time to replace it right now.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Magic Chef oven not working, stove top buners work fine. DKILBY Oven Repair (including Ranges and Cooktops) 1 12-29-2010 09:43 PM
magic chef oven doesn't work suree Oven Repair (including Ranges and Cooktops) 1 12-28-2009 12:04 PM
My magic chef oven does not work top works fine Iphonehuff Oven Repair (including Ranges and Cooktops) 0 12-11-2009 10:02 AM
Whirlpool oven not work,stovetop works fine ARTI Oven Repair (including Ranges and Cooktops) 1 10-11-2009 08:51 AM
oven won't work but burners fine Stan Kutnicki Oven Repair (including Ranges and Cooktops) 7 10-04-2009 06:38 PM
