Discuss
50's kenmore range oven
 in
The oven was first only heating up to 250 degrees...by the time I got over to look at the oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » 50's kenmore range oven
  #1 (permalink)
Old 12-09-2009, 07:07 AM
Junior Member
jthom is on a distinguished road
Default 50's kenmore range oven
Model Number: 103.243001   Brand: Kenmore   Age: More than 10 years
The oven was first only heating up to 250 degrees...by the time I got over to look at the oven it was not turn on at all. The oven has a BJ model thermostat with two tubes running from it to the oven. One is about 1/8" and goes to the hole for light the oven in the oven bottom pan. The other is a 7/8" tubing for the main gas suplly to the oven.
Now the oven will not light. The oven does not have a pilot light but the round port on the front of the bottom oven pan where you hold a match to light. If I remove the oven pan the 1/8" tubing end will burn a very small flame when a lighter is but directly to the end of it. But the burner will still not come on. The thermostat capillary tube is held at the top of the oven.
My questions are: Can the 1/8" lines, 7/8" line and the burner assembly be blown out with an air compressor to get the unit to work?...could the thermostat capillary be the problem and can I get a replacement for this old style?
Or is this requiring another thermostat / rebuild. If I remove the thermostat how can I cap of the gas to the thermostat so I can still use the burners?
Would appreciate any and all suggestions.
J. Thom
Ads By Google
Related Models
Kenmore 103.3017000  LINER KIT
Kenmore 103.30181  KENMORE GAS OVEN
Kenmore 103.3023200  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3023210  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3025200  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3026520  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3026521  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3033400  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3033410  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3035000  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3035400  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3035500  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3035600  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3035800  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3035900  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036500  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036501  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036540  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036541  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036550  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036551  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036560  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036561  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036580  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036581  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036590  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036591  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.30381  KENMORE GAS OVEN
Kenmore 103.3043200  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3043210  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3045200  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3046520  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3046521  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3347201  KENMORE 30 IN GAS COUNTER UNIT
Kenmore 103.3347202  KENMORE 30 IN GAS COUNTER UNIT
Kenmore 103.3347212  KENMORE 30 IN GAS COUNTER UNIT
Kenmore 103.3347222  KENMORE 30 IN GAS COUNTER UNIT
Kenmore 103.3347242  KENMORE 30 IN GAS COUNTER UNIT
Kenmore 103.3347262  KENMORE 30 IN GAS COUNTER UNIT
Kenmore 103.3347282  KENMORE 30 IN GAS COUNTER UNIT
Kenmore 103.3347810  KENMORE 30 IN GAS COUNTER UNIT
Kenmore 103.3347811  KENMORE 30 IN GAS COUNTER UNIT
Kenmore 103.3348210  KENMORE 30 IN GAS COUNTER UNIT
Kenmore 103.3378811  30" GAS COUNTER UNIT
Kenmore 103.4017210  LINER KIT
Kenmore 103.4017220  LINER KIT
Kenmore 103.4023200  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4023210  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4025200  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4026520  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4033400  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4033410  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4035000  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4035400  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4035500  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4035600  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4035800  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4035900  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4036500  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4036540  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4036550  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4036560  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4036570  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4036580  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4036590  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4043200  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4043210  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4045200  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4046520  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4053000  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4053010  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4053400  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4053410  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4053500  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4053510  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4053600  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4053710  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4053800  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4053810  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4055000  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4055400  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4055500  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4055600  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4055800  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4055900  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4056500  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4056540  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 103.4407910  KENMORE 36 INCH INDUCTION GLASS TOP COUNTER UNIT
Kenmore 103.4407911  KENMORE 36 INCH INDUCTION GLASS TOP COUNTER UNIT
Kenmore 103.52600  KENMORE RANGE HOOD
Kenmore 103.52606  KENMORE RANGE HOOD
Kenmore 103.52609  KENMORE RANGE HOOD
Kenmore 103.52660  KENMORE RANGE HOOD
Kenmore 103.52664  KENMORE RANGE HOOD
Kenmore 103.5266600  KENMORE RANGE HOOD
Kenmore 103.5266640  KENMORE RANGE HOOD
Kenmore 103.5266700  KENMORE RANGE HOOD
Kenmore 103.5266701  KENMORE RANGE HOOD
Kenmore 103.5266740  KENMORE RANGE HOOD
Kenmore 103.5266741  KENMORE RANGE HOOD
Kenmore 103.5266760  KENMORE RANGE HOOD
Kenmore 103.5266761  KENMORE RANGE HOOD
Kenmore 103.52700  KENMORE RANGE HOOD
Kenmore 103.52760  KENMORE RANGE HOOD
Kenmore 103.52764  KENMORE RANGE HOOD
Kenmore 103.5276600  KENMORE RANGE HOOD
Kenmore 103.5276640  KENMORE RANGE HOOD
Kenmore 103.5276700  KENMORE RANGE HOOD
Kenmore 103.5276701  KENMORE RANGE HOOD
Kenmore 103.5276740  KENMORE RANGE HOOD
Kenmore 103.5276741  KENMORE RANGE HOOD
Kenmore 103.5276760  KENMORE RANGE HOOD
Kenmore 103.5276761  KENMORE RANGE HOOD
Kenmore 103.5277000  KENMORE RANGE HOOD
Kenmore 103.5277020  KENMORE RANGE HOOD
Kenmore 103.5277040  KENMORE RANGE HOOD
Kenmore 103.5277060  KENMORE RANGE HOOD
Kenmore 103.5277100  KENMORE DUCTED RANGE HOOD
Kenmore 103.5277120  KENMORE DUCTED RANGE HOOD
Kenmore 103.5277140  KENMORE DUCTED RANGE HOOD
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore range by Whirlpool - oven won't light chingliu Oven Repair (including Ranges and Cooktops) 27 09-23-2009 05:10 PM
Kenmore range oven don't work R80True Oven Repair (including Ranges and Cooktops) 8 01-16-2009 12:36 PM
Kenmore oven/range won't turn off JillGaskin Oven Repair (including Ranges and Cooktops) 3 01-15-2009 03:27 PM
Kenmore range oven/clock dead 21rocket Oven Repair (including Ranges and Cooktops) 0 12-30-2008 03:08 PM
kenmore Propane oven range bubbankyle Oven Repair (including Ranges and Cooktops) 0 12-22-2008 06:04 PM
