Discuss
oven door locked
 in
Our oven door is locked and we can't get it unlocked. We had a major power failure and now
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven door locked
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
LinkBack (7) Thread Tools Search this Thread Display Modes
  7 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 07-20-2007, 05:17 PM
jmiller jmiller is offline
Junior Member
jmiller is on a distinguished road
Default oven door locked
Model Number: rf386pxe   Brand: Whirlpool   Age: 1 - 5 years
Our oven door is locked and we can't get it unlocked. We had a major power failure and now the door is locked. It has an F5 error which will not clear
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-20-2007, 05:19 PM
Junior Member
Default
oven door locked and can't get it to release
  #3 (permalink)
Old 07-20-2007, 06:05 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Hi jmiller,
F5 error code stands for a problem with the door latch.
To unlock the door:
First, disconnect the power to the range (either unplug it or turn the power off at the circuit breaker). Pull the range out and remove the back panel. Your range has a door latch in the front and a door latch solenoid (with latch switches) in the back. There is a thin metal rod that connects the two. When the board sends a signal to the solenoid to lock the door, the solenoid turns the rod which locks the latch. With the back panel off, you should now see both the solenoid and the rod. You can now manually release the latch by turning the rod (probably clockwise). You should now be able to open the door.
Put everything back the way it was and with the door open turn the power back on. Press and hold any key on the board for one minute. This should release the error code. Press CANCEL and give it a few minutes to see if the code comes back. If it doesn't, you can start baking (by the way, I like oatmeal cookies ). If it does come back, you'll need to test the latch switches and the solenoid.
Here is a tech sheet from Whirlpool that will tell you how to test the latch switches (See F5 under FAILURE/ERROR CODES).
If you need any parts for this model, use the following link (make sure to get the complete model number off the oven, now that the door is open): Whirlpool models starting with RF386PXE
Let us know how it goes...
Reply
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/63-oven-door-locked.html
Posted By For Type Date
Digg - How to open a locked oven door This thread Refback 12-09-2007 06:39 PM
digg / postaholic / news / submitted This thread Refback 08-15-2007 05:51 AM
Digg - Who dugg or blogged: How to open a locked oven door This thread Refback 08-01-2007 02:10 PM
Digg - How to open a locked oven door This thread Refback 07-23-2007 07:06 PM
Digg / Offbeat News / Upcoming This thread Refback 07-23-2007 07:00 PM
Digg / News / Upcoming This thread Refback 07-23-2007 04:59 PM
Digg / News / Upcoming This thread Refback 07-23-2007 04:56 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
