Discuss
Whirlpool oven doesn't heat
 in
My Whirlpool electric oven (rbs275pd) will not heat. When I hold stop button for 5 secs. it displays E0 F0
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool oven doesn't heat
  #1 (permalink)
Old 12-07-2009, 06:32 PM
Junior Member
bullfrog is on a distinguished road
Default Whirlpool oven doesn't heat
Model Number: rbs275pd   Brand: Whirlpool   Age: 1 - 5 years
My Whirlpool electric oven (rbs275pd) will not heat. When I hold stop button for 5 secs. it displays E0 F0 code? What do I need to do to fix this oven? Fan, timer, clock all work.
Ads By Google
Related Models
Whirlpool RBS275PDB1
Whirlpool RBS275PDB10
Whirlpool RBS275PDB11
Whirlpool RBS275PDB12
Whirlpool RBS275PDB13
Whirlpool RBS275PDB14
Whirlpool RBS275PDB16 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDB17 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDB2
Whirlpool RBS275PDB4
Whirlpool RBS275PDB6
Whirlpool RBS275PDB8
Whirlpool RBS275PDQ1
Whirlpool RBS275PDQ10
Whirlpool RBS275PDQ11
Whirlpool RBS275PDQ12
Whirlpool RBS275PDQ13
Whirlpool RBS275PDQ14
Whirlpool RBS275PDQ16 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDQ17 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDQ2
Whirlpool RBS275PDQ4
Whirlpool RBS275PDQ6
Whirlpool RBS275PDQ8
Whirlpool RBS275PDS12
Whirlpool RBS275PDS14
Whirlpool RBS275PDS16 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDS17 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDT10
Whirlpool RBS275PDT11
Whirlpool RBS275PDT12
Whirlpool RBS275PDT13
Whirlpool RBS275PDT14
Whirlpool RBS275PDT16 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDT17 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PRB00 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PRQ00 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PRS00 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PRT00 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS277PDB1
Whirlpool RBS277PDB2
Whirlpool RBS277PDB4
Whirlpool RBS277PDQ1
Whirlpool RBS277PDQ2
Whirlpool RBS277PDQ4
Whirlpool RBS305PDB1
Whirlpool RBS305PDB10
Whirlpool RBS305PDB11
Whirlpool RBS305PDB12
Whirlpool RBS305PDB13
Whirlpool RBS305PDB14
Whirlpool RBS305PDB16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDB17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDB2
Whirlpool RBS305PDB4
Whirlpool RBS305PDB6
Whirlpool RBS305PDB8
Whirlpool RBS305PDB9
Whirlpool RBS305PDQ1
Whirlpool RBS305PDQ10
Whirlpool RBS305PDQ11
Whirlpool RBS305PDQ12
Whirlpool RBS305PDQ13
Whirlpool RBS305PDQ14
Whirlpool RBS305PDQ16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDQ17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDQ2
Whirlpool RBS305PDQ4
Whirlpool RBS305PDQ6
Whirlpool RBS305PDQ8
Whirlpool RBS305PDQ9
Whirlpool RBS305PDS12
Whirlpool RBS305PDS14
Whirlpool RBS305PDS16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDS17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT10
Whirlpool RBS305PDT11
Whirlpool RBS305PDT12
Whirlpool RBS305PDT13
Whirlpool RBS305PDT14
Whirlpool RBS305PDT16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT8
Whirlpool RBS305PDT9
Whirlpool RBS305PDZ1
Whirlpool RBS305PDZ10
Whirlpool RBS305PDZ2
Whirlpool RBS305PDZ4
Whirlpool RBS305PDZ6
Whirlpool RBS305PDZ8
Whirlpool RBS305PDZ9
Whirlpool RBS305PRB00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRQ00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRS00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRT00 30" Built - in Electric Oven Self Clean
Whirlpool RBS307PDB1
Whirlpool RBS307PDB2
Whirlpool RBS307PDB4
Whirlpool RBS307PDQ1
Whirlpool RBS307PDQ2
Whirlpool RBS307PDQ4
Frigidaire RBSF117E1 BLACK Frg(v3) / Electric Cooktops and Control Box
Frigidaire RBSF117EL1 Frg(v2) / Electric Cooktops and Control Box
Frigidaire RBSF117EW1 Frg(v1) / Electric Cooktops and Control Box
Frigidaire RBSF129EL0 Frg(v4) / Electric Range
Frigidaire RBSF129EW0 Frg(v3) / Electric Range
Frigidaire RBUGCF95ED Frg(v6) / Wall Oven
Frigidaire RBUGCF95EK Frg(v7) / Wall Oven
Frigidaire RBUGCF95EW Frg(v5) / Wall Oven
Amana RC-10B Commercial Microwaves
Amana RC-10B-DD Commercial Microwaves
Amana RC-10B-PB Commercial Microwaves
Amana RC-10D Commercial Microwaves
  #2 (permalink)
Old 12-08-2009, 04:09 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Your Model Number is short several digits.
Please check it as there are a number of different data sheets/wiring diagrams.
The F0 E0 code is that there is no error, as far as I can tell.
Try flipping the breaker off/on slowly a couple times. Often you can loose half the line without actually tripping the breaker and the elements require the full 240 volts. Fan, control and lights only need 120 volts.
Better yet measure it at the plug.
L1 to L2 should be 240 volts
L1 to Neutral and L2 to Neutral, both should be 120 volts
Unplug the unit and check that a wire has not burned off at the unit's terminal strip.
Also many units have a thermal fuse or thermostat inline with the elements perhaps it is blown.
__________________
  #3 (permalink)
Old 10-20-2011, 06:46 PM
Junior Member
kidwells is on a distinguished road
Default Help with Whirlpool electric oven
[While using our self cleaning mode we had a power outage and now the our Whirlpool accucook oven will not heat up. It is showing E0 and F0 code
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Oven won't heat up jims Oven Repair (including Ranges and Cooktops) 66 01-14-2011 08:28 PM
Whirlpool oven doesn't heat SandraLee Oven Repair (including Ranges and Cooktops) 2 12-15-2010 02:12 PM
Whirlpool Oven will not heat up John Kazminski Oven Repair (including Ranges and Cooktops) 0 12-22-2009 06:40 PM
Whirlpool oven won't heat Lamb Oven Repair (including Ranges and Cooktops) 4 08-04-2009 08:17 PM
Whirlpool oven won't heat up dlchunting Oven Repair (including Ranges and Cooktops) 5 12-02-2008 09:03 AM
