Discuss
Oven Not Firing up
 in
I have an oven that when you turn it on you can see the glow at the botton of the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Not Firing up
  #1 (permalink)
Old 03-13-2008, 04:02 PM
macaldwell macaldwell is offline
Junior Member
macaldwell is on a distinguished road
Cool Oven Not Firing up
Model Number: 30-2251-00-07   Brand: Tappan   Age: More than 10 years
I have an oven that when you turn it on you can see the glow at the botton of the oven but it sits there for several minutes without firing, on a very rare occasion you can get it to fire up. I have seen a few posts that safety valve may be bad or the ignitor as well. Is there a way to get a definite determintion of the problem and how hard is it to replace these parts on the oven? Your advice is greatly appreciated.
Thanks,
Mark
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-14-2008, 02:12 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Mark,
Most likely the problem is a bad igniter.
You can learn how oven igniter works from one of my previous posts: Oven won't lite?
- The part number for the oven igniter is AP2150412
Here are the break down diagrams for the Tappan range Model 30-2251-00-07
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-14-2008, 06:30 PM
Matt S Matt S is offline
Senior Expert
APP Volunteer
Matt S is on a distinguished road
Default
Yup, bad ignitor.
I know it seems counter-intuitive. But, trust me, it is NOT the bake valve, it is the ignitor. It is common for people to change the valve assuming that the ignitor must be good because it is glowing. But, if the ignitor does not pull enough amps, the valve will not open.
Most ignitors go bad between 4 and 6 years old.
Matt
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore front lod washer sounds like a machine gun firing! mikedipasquale Washer Repair 1 02-26-2008 05:11 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
