| » Oven light now always on |
Model Number: JSP31GN Brand: GE Age: More than 10 years
I couldn't unscrew the light bulb, so I broke it (Yes, after throwing the circuit breaker!) and used pliers to remove the base. Unfortunately, the brass socket in the lamp holder also came out. I turned the power back on and screwed in a bulb to determine the 'status' of the lamp base, and now the light is always on. Will replacing the lamp holder (P/N PS 256 842) fix this problem? OR has something happened elsewhere?
I would have thought the front-panel oven light switch controlled the power before it got to the socket, but reading some of the posts here, it's more likely that this switch is wired to a relay on the control board. All other stove functions work. Thanks in advance. (I used to be able to work on my car too!) Ads By Google Related Models |
| Display Modes | |
| Oven burner wont light or takes a long time to light | shadyray | Oven Repair (including Ranges and Cooktops) | 4 | 01-30-2011 08:26 PM |
| Blinking Blue Lights (Oven ON Light & Oven Heating Light | bubbah2os | Oven Repair (including Ranges and Cooktops) | 1 | 02-05-2010 01:07 PM |
| kenmore oven will light, bring oven to temp, but won't re-light after the temp.... | weedsnager | Oven Repair (including Ranges and Cooktops) | 1 | 12-02-2009 05:28 PM |
| Oven doesn't light, Broil and Preheat will light | tisears | Oven Repair (including Ranges and Cooktops) | 1 | 09-09-2009 12:38 PM |
| magic chef propane oven won't light (has pilot light) | A and J | Oven Repair (including Ranges and Cooktops) | 3 | 09-19-2008 12:36 PM |
