Discuss
F10 code for a Kenmore Gas Range
 in
Whenever I set my oven temperature above 375 degrees, once it reaches that temperature the F10 code comes on and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » F10 code for a Kenmore Gas Range
  #1 (permalink)
Old 12-06-2009, 05:14 PM
Junior Member
tgilham is on a distinguished road
Default F10 code for a Kenmore Gas Range
Model Number: 790.78573401   Brand: Kenmore   Age: 1 - 5 years
Whenever I set my oven temperature above 375 degrees, once it reaches that temperature the F10 code comes on and starts beeping. I have to turn the oven off and wait. I can't bake anything that requires a temperature above 375 degrees. Since our local repair shop does not handle Kenmores but will repair it if he has an idea which part should be replaced. I would like to know which part is likely to be the culprit and what exact part number should I tell him to order.
Several posts from other sites have said it may be the EOC Probe or it also could be the bake burner igniter.
My oven doesn't overheat when I get this code.
Ads By Google
Related Models
Kenmore 790.79012100  GAS RANGE
Kenmore 790.79013100  GAS RANGE
Kenmore 790.79014100  GAS RANGE
Kenmore 790.79019100  GAS RANGE
Kenmore 790.79112200  SEARS/GAS RANGE
Kenmore 790.79112201  SEARS/GAS RANGE
Kenmore 790.79112202  SEARS/GAS RANGE
Kenmore 790.79113200  SEARS/GAS RANGE
Kenmore 790.79113201  SEARS/GAS RANGE
Kenmore 790.79113202  SEARS/GAS RANGE
Kenmore 790.79114200  SEARS/GAS RANGE
Kenmore 790.79114201  SEARS/GAS RANGE
Kenmore 790.79114202  SEARS/GAS RANGE
Kenmore 790.79119200  SEARS/GAS RANGE
Kenmore 790.79119201  SEARS/GAS RANGE
Kenmore 790.79119202  SEARS/GAS RANGE
Sears 790.8  OUTDOORS POST & WALL LAMP
Kenmore 790.8  HAIR CLIPPERS
Kenmore 790.90102200  ELECTRIC RANGE
Kenmore 790.90104200  ELECTRIC RANGE
Kenmore 790.91010200  ELECTRIC RANGE
Kenmore 790.91011200  ELECTRIC RANGE
Kenmore 790.91012300  ELECTRIC RANGE
Kenmore 790.91014300  ELECTRIC RANGE
Kenmore 790.91022102  RANGE
Kenmore 790.91102000  ELECTRIC RANGE
Kenmore 790.91102001  ELECTRIC RANGE
Kenmore 790.91105890  ELECTRIC RANGE
Kenmore 790.91105891  ELECTRIC RANGE
Kenmore 790.91105892  ELECTRIC RANGE
Kenmore 790.91106890  ELECTRIC RANGE
Kenmore 790.91106891  ELECTRIC RANGE
Kenmore 790.91106892  RANGE
Kenmore 790.91107000  ELECTRIC RANGE
Kenmore 790.91107001  ELECTRIC RANGE
Kenmore 790.9115892  ELECTRIC RANGE
Kenmore 790.9116892  ELECTRIC RANGE
Kenmore 790.92310100  ELECTRIC RANGE
Kenmore 790.92311100  ELECTRIC RANGE
Kenmore 790.92312100  ELECTRIC RANGE
Kenmore 790.92312300  ELECTRIC RANGE
Kenmore 790.92313300  ELECTRIC RANGE
Kenmore 790.92314100  ELECTRIC RANGE
Kenmore 790.92314300  ELECTRIC RANGE
Kenmore 790.92315100  ELECTRIC RANGE
Kenmore 790.92410100  ELECTRIC RANGE
Kenmore 790.92410102  ELECTRIC RANGE
Kenmore 790.92410103  ELECTRIC RANGE
Kenmore 790.92410104  ELECTRIC RANGE
Kenmore 790.92411100  ELECTRIC RANGE
Kenmore 790.92411102  ELECTRIC RANGE
Kenmore 790.92411103  ELECTRIC RANGE
Kenmore 790.92411104  ELECTRIC RANGE
Kenmore 790.92412100  ELECTRIC RANGE
Kenmore 790.92412102  ELECTRIC RANGE
Kenmore 790.92412103  ELECTRIC RANGE
Kenmore 790.92412104  ELECTRIC RANGE
Kenmore 790.92413200  ELECTRIC RANGE
Kenmore 790.97471790  ELECTRIC RANGE
Kenmore 790.97475790  ELECTRIC RANGE
Kenmore 790.97476790  ELECTRIC RANGE
Kenmore 790.97478790  ELECTRIC RANGE
Kenmore 791.0  HAIR CLIPPERS
Kenmore 791.4  HAIR CLIPPERS
Kenmore 791.6102190  GAS RANGE
Kenmore 791.6102890  GAS RANGE
Kenmore 791.6112190  GAS RANGE
Kenmore 791.6112890  GAS RANGE
Kenmore 791.6162190  GAS RANGE
Kenmore 791.6162890  GAS RANGE
Kenmore 791.6262190  ELECTRIC RANGE
Kenmore 791.6262890  ELECTRIC RANGE
Kenmore 791.6272190  ELECTRIC RANGE
Kenmore 791.6272890  ELECTRIC RANGE
Kenmore 791.6302190  GAS RANGE
Kenmore 791.6302890  GAS RANGE
Kenmore 791.6412190  ELECTRIC RANGE
Kenmore 791.6412890  ELECTRIC RANGE
Kenmore 791.734891  GAS RANGE
Kenmore 791.734898  GAS RANGE
Kenmore 791.783889  GAS RANGE
Kenmore 791.7838890  KENMORE GAS RANGE
Kenmore 791.7838891  GAS RANGE
Kenmore 791.7839090  GAS RANGE
Kenmore 791.7839091  GAS RANGE
Kenmore 791.7839092  GAS RANGE
Kenmore 791.7839094  GAS RANGE
Kenmore 791.785889  GAS RANGE
Kenmore 791.7858890  KENMORE GAS RANGE
Kenmore 791.7858892  GAS RANGE
Kenmore 791.7859090  GAS RANGE
Kenmore 791.7859091  GAS RANGE
Kenmore 791.7859092  GAS RANGE
Kenmore 791.7859093  GAS RANGE
Kenmore 791.7859094  GAS RANGE
Kenmore 791.7859095  GAS RANGE
Kenmore 791.7898810  KENMORE GAS RANGE
Kenmore 791.7898814  GAS RANGE
Kenmore 791.7898815  GAS RANGE
Kenmore 791.7898884  GAS RANGE
Kenmore 791.7898885  GAS RANGE
Kenmore 791.7898894  GAS RANGE
Kenmore 791.7898895  GAS RANGE
Kenmore 791.7899010  GAS RANGE
Kenmore 791.7899011  GAS RANGE
Kenmore 791.7899012  GAS RANGE
Kenmore 791.7899080  GAS RANGE
Kenmore 791.7899081  GAS RANGE
Kenmore 791.7899082  GAS RANGE
Kenmore 791.7899090  GAS RANGE
Kenmore 791.7899091  GAS RANGE
Kenmore 791.7899092  GAS RANGE
Kenmore 791.9338911  ELECTRIC RANGE
Kenmore 791.9338913  ELECTRIC RANGE
Kenmore 791.9338981  ELECTRIC RANGE
Kenmore 791.9338983  ELECTRIC RANGE
Magic Chef 79F-5EXW
Magic Chef 79FA-5EVW
Magic Chef 79FA-5EXW
Magic Chef 79FK-5EVW
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore elite Glass Top Range F5-01 error code hulagirlmele Oven Repair (including Ranges and Cooktops) 1 09-02-2009 04:00 PM
Kenmore Elite Range error code help jayp Oven Repair (including Ranges and Cooktops) 15 07-08-2009 02:27 PM
Kenmore Elite range Error code problem Baywood Oven Repair (including Ranges and Cooktops) 0 12-26-2008 06:13 PM
Kenmore Range error code F2-E0 mtfurtney Oven Repair (including Ranges and Cooktops) 1 01-28-2008 10:27 AM
F2 Error Code for Kenmore Range familykg Oven Repair (including Ranges and Cooktops) 1 01-21-2008 12:46 PM
