Discuss
oven will not turn off
 in
I currently own an Amana electric self clean oven. It shouldn't be more then 10 years old. Part no is
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven will not turn off
  #1 (permalink)
Old 12-06-2009, 01:38 PM
Junior Member
cory seiler is on a distinguished road
Default oven will not turn off
Model Number: ARR6202   Brand: Amana   Age: 5 - 10 years
I currently own an Amana electric self clean oven. It shouldn't be more then 10 years old. Part no is 35-31680501-0. Last night we stared the oven without any issues and turned the knob off after with no problems. This morning the knob was still off but a small portion of the coil was still getting electricity (it was still orange with heat). I'm not sure if there is a broken coil or what may need to be replaced. I am going to shut off and restart the breaker today but if that doesn't work I am wondering what options/solutions I have.
Please help me out
Cory Seiler
Ads By Google
Related Models
Amana ARR6202L Range - S/c S/i Ddraft Gas
Amana ARR6202W Range - S/c S/i Ddraft Gas
Amana ARR620W1 Range - S/c S/i Ddraft Ele
Amana ARR6220C Range - S/c S/i Ddraft Gas
Amana ARR6220L Range - S/c S/i Ddraft Gas
Amana ARR6220W Range - S/c S/i Ddraft Gas
Amana ARR623L Range - S/c S/i Ddraft Ele
Amana ARR623L,W Range - S/c S/i Ddraft Gas
Amana ARR623W Range - S/c S/i Ddraft Ele
Amana ARR624L Range - S/c S/i Ddraft Ele
Amana ARR624L1 Range - S/c S/i Ddraft Ele
Amana ARR624W Range - S/c S/i Ddraft Ele
Amana ARR624W1 Range - S/c S/i Ddraft Ele
Amana ARR625L Range - S/c S/i Ddraft Ele
Amana ARR625L,W Range - S/c S/i Ddraft Gas
Amana ARR625W Range - S/c S/i Ddraft Ele
Amana ARR626L Range - S/c S/i Ddraft Ele
Amana ARR626L1 Range - S/c S/i Ddraft Ele
Amana ARR626W Range - S/c S/i Ddraft Ele
Amana ARR626W1 Range - S/c S/i Ddraft Ele
Amana ARR626WW Range - S/c S/i Ddraft Ele
Amana ARR629L Range - S/c S/i Ddraft Ele
Amana ARR629L,W Range - S/c S/i Ddraft Ele
Amana ARR629W Range - S/c S/i Ddraft Ele
Amana ARR629WW Range - S/c S/i Ddraft Ele
Amana ARR630 Range - S/c S/i Ddraft Ele
Amana ARR6300LL Range - S/c S/i Ddraft Ele
Amana ARR6300W Range - S/c S/i Ddraft Ele
Amana ARR6300WW Range - S/c S/i Ddraft Ele
Amana ARR630L Range - S/c S/i Ddraft Ele
Amana ARR630L1 Range - S/c S/i Ddraft Ele
Amana ARR630LL Range - S/c S/i Ddraft Ele
Amana ARR630W Range - S/c S/i Ddraft Ele
Amana ARR630W1 Range - S/c S/i Ddraft Ele
Amana ARR630WW Range - S/c S/i Ddraft Ele
Amana ARR632E Range - S/c S/i Ddraft Ele
Amana ARR632WW Range - S/c S/i Ddraft Ele
Amana ARR633E Range - S/c S/i Ddraft Ele
Amana ARR633W Range - S/c S/i Ddraft Ele
Amana ARR633WW Range - S/c S/i Ddraft Ele
Amana ARR6400L Range - S/c S/i Ddraft Gas
Amana ARR6400LL Range - S/c S/i Ddraft Gas
Amana ARR6400W Range - S/c S/i Ddraft Gas
Amana ARR6400WW Range - S/c S/i Ddraft Gas
Amana ARR6420CC Range - S/c S/i Ddraft Gas
Amana ARR6420WW Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 12-07-2009, 04:43 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for ARR6202 models | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/maytag.../T232_14R4.pdf
Since it was not bright red it sounds like part of the coil is getting 120 volts.
This can happen if the coil shorts out to one of the feet or mounts.
It then gets power from the line and completes the circuit through the short to the frame.
You could unplug the unit, remove the element and check it with a meter.
Should be approximately 20 ohms. Then check from each side of the element to the mount and the feet all should be infinite ohms (open).
Note it is a good idea to clip something (clothes pin etc.) onto the element wires so they do not disappear into the back of the unit.
Another way to check is if lets say the element is orange from the mount to the left side foot. Unplug the unit and then place a nonconducting heat resistant material between the foot and the oven floor. Then plug it in and give it a try if the section does not heat up then the element needs replacing.
A saucer may be used as long as you do not let it get too hot.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven will not turn off lbrown Oven Repair (including Ranges and Cooktops) 1 03-23-2011 08:31 AM
Set-in oven won't turn off. tdtk42 Oven Repair (including Ranges and Cooktops) 2 11-07-2009 09:14 AM
Maytag Stove/Oven - oven will not turn off bodnarja Oven Repair (including Ranges and Cooktops) 6 11-01-2009 02:23 AM
Oven won't turn off JDMACRAE Oven Repair (including Ranges and Cooktops) 8 06-24-2009 07:56 AM
Oven won't turn off rg99 Oven Repair (including Ranges and Cooktops) 8 03-13-2009 04:11 AM
