| » Oven does not heat after using Cleaning Cycle |
Model Number: KEBS107DBL7 Brand: Kitchen Aid Age: More than 10 years
It appears I made the rookie mistake of using the cleaning cycle on my oven. Since then the element will not heat up. Control pannel, oven light, and convection fan all work just no heat. What to replace?
Thanks in advance for the help. Thomas Ads By Google Related Models |
Replacement parts for WHIRLPOOL KEBS107DBL7 | AppliancePartsPros.com Here is the tech sheet http://www.servicematters.com/docs/w...%204451876.pdf Check out Page 5 Thermal Fuse. Remove power from the unit and check the fuse with a meter, should be 0 ohms. Be sure to remove one wire from it when doing this as theis prevents reading an alternate/parallel circuit path.
__________________
Thanks Denman.
I am having some trouble identifying the Oven shutdown thermal fuse. I only see the convection bake element, Oven temperature sensor and broil element conection. Is the fuse on the outside(back) of the oven? Do I need to pull the oven out to get to it? Also, I guess this is part #37 on the parts diagram? Thanks again! Thomas |
Yes Do I need to pull the oven out to get to it? Unfortunaetly yes, as far as I know. This may be helpful https://secured.whirlpool.com/Servic...all%20Oven.pdf Also, I guess this is part #37 on the parts diagram Yes
__________________
| Display Modes | |
| Oven not working after self cleaning cycle | jivery | Oven Repair (including Ranges and Cooktops) | 12 | 02-04-2011 05:08 PM |
| GE Oven Cleaning Cycle Won't Work :-( | ShoBizzzz | Oven Repair (including Ranges and Cooktops) | 0 | 11-08-2009 06:44 PM |
| Oven does not work after self-cleaning cycle | Wufpak | Oven Repair (including Ranges and Cooktops) | 5 | 02-22-2009 08:21 PM |
| Built-inWhirlpool single oven won't heat after cleaning cycle | Gail | Oven Repair (including Ranges and Cooktops) | 1 | 11-01-2008 12:27 AM |
| After Cleaning Cycle - Oven does not work | bokeldol | Oven Repair (including Ranges and Cooktops) | 5 | 01-09-2008 06:59 PM |
