Discuss
Will the cooktop work if the computer...
 in
clock assembly is disconnected and removed for repair? There are some bare ends of the connecting cables that might be
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Will the cooktop work if the computer...
  #1 (permalink)
Old 12-05-2009, 12:30 PM
Junior Member
AGJim is on a distinguished road
Default Will the cooktop work if the computer...
Brand: Jenn-Air   Age: 1 - 5 years
clock assembly is disconnected and removed for repair? There are some bare ends of the connecting cables that might be a problem. But it seems there is no connection between the computer assembly and the stovetop knobs. But, I am scared to just plug it in.
Thanks!
  #2 (permalink)
Old 12-05-2009, 12:36 PM
Member
gmbdinc is on a distinguished road
Default
DO NOT RISK IT!!! There are several voltage connections in common throughout the stove. I f you inadvertantly cross them, Short them, POW!!! Your toast.
JUST A SUGGESTION.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Oven cooktop does not work aponte Oven Repair (including Ranges and Cooktops) 1 02-05-2010 04:48 AM
Cooktop element won't work joycep Oven Repair (including Ranges and Cooktops) 0 01-11-2010 06:34 AM
Thermador cooktop ignitor does not work Homemaker909 Oven Repair (including Ranges and Cooktops) 0 11-15-2009 10:12 PM
oven does not work, cooktop works djgeorge Oven Repair (including Ranges and Cooktops) 7 02-16-2009 06:27 AM
cooktop igniter wont work Dwayne landrum Oven Repair (including Ranges and Cooktops) 1 02-07-2008 05:53 PM
