| » Oven/clock Control Panel is no longer lit but oven does heat. |
Model Number: SVE47600B Brand: Jenn-Air Age: More than 10 years
Please help me determine what has happened to my Oven Control Panel. No numbers are ever lit, it remains dark despite pushing buttons. Oven is working but never shows any display. I did recently clean under the oven and wondered if something got loose. What are the steps to diagnose this issue please?
Replacement parts for SVE47600B models | AppliancePartsPros.com Here is a manual which may help http://www.servicematters.com/maytag...s/16010191.pdf Usually this is the control board here is a good thread about this issue Thermador display is very dim I would check, disconnect and reconnect all the plugs on the relay board and the control board. Be sure to unplug/remove power from the unit when doing this
__________________
| Display Modes | |
| Burners and oven no longer heat...HELP! | Infinity35 | Oven Repair (including Ranges and Cooktops) | 2 | 05-19-2012 09:51 AM |
| clock/oven panel don't work | frederic | Oven Repair (including Ranges and Cooktops) | 1 | 11-10-2009 03:00 PM |
| clock/oven panel don't work | frederic | Oven Repair (including Ranges and Cooktops) | 0 | 11-10-2009 12:44 PM |
| F2 code on oven/clock panel | Bluecrab | Oven Repair (including Ranges and Cooktops) | 3 | 02-18-2009 04:08 PM |
| Kenmore Electric Range clock / oven control panel | dezrailer | Oven Repair (including Ranges and Cooktops) | 1 | 11-27-2007 02:46 PM |
