Discuss
GE downdraft vent system
 in
When unit retracts, motor does not shut off and continues to hum. I must unplug it to get it to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE downdraft vent system
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-19-2007, 11:47 AM
R Grubb R Grubb is offline
Junior Member
R Grubb is on a distinguished road
Default GE downdraft vent system
Model Number: JVB67A1BB   Brand: GE   Age: 5 - 10 years
When unit retracts, motor does not shut off and continues to hum. I must unplug it to get it to stop. It is fully retracted when this happens. It will not raise either.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-21-2007, 01:17 AM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
I don't see a lower limit switch, in fact I don't see any limit switches there, so I'm assuming the problem is with the control board at the bottom (#22 on the diagram).
- Replacement control board
  #3 (permalink)
Old 09-27-2007, 12:56 PM
jlance jlance is offline
Junior Member
jlance is on a distinguished road
Smile have exact same problem
My problem is identical to what you described.
Used GE instructions I found inside the electrical box to dismantle unit.
Discovered the problem was the up/down motor. Motor was making noise like it was spinning. Just did not have enough juice to fully turn over and raise the vent. If you gave it a little assist it would work. I have ordered a new motor. It's not too bad to get at once you get it apart.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE id system 2.0 reader101 Washer Repair 0 08-13-2007 02:56 PM
humming coming from the bottom of system ahchitski Dishwasher Repair 1 07-23-2007 03:03 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
