I have a roper oven model: bes750wb and need a wiring diagram to see what I am getting into. I need to check on "F 1 & F3" faults.:confused:
THIS FORUM IS DEAD!!!!!!! |
Thanks, I will be working on it Sun & Mon. After talking with my wife again the Fault was "F2" & "F3", Not "F1". Does this help explain it any better?:confused:
Does this help explain it any better? Both codes could be a bad sensor so I would start there. |
Originally Posted by: denman Does this help explain it any better? Both codes could be a bad sensor so I would start there. I put a new sensor in and I still get the same f2 & f3 codes on the elecrtonic top oven controller. Even when I am using the bottom oven that is not the electronic controller the codes pop up on the top oven controller.:confused:
Unfortunately it sounds like the control board is giving you a false error. |
Originally Posted by: denman Unfortunately it sounds like the control board is giving you a false error. I have ordered a controller. IT MUST BE A REMANUFACTURED UNIT SINCE THEY WANTED A CORE CHARGE THAT WILL BE REFUNDED WHEN I GIVE THEM THE OLD ONE. HOPE THIS SOLVES THE PROBLEM. THANKS FOR THE HELP.
