| » Oven deaded after self-cleaning |
Model Number: mew6530dds Brand: Maytag Age: 1 - 5 years
Dear,
My oven could not work after self-cleaning. The clock is still work but can not do anything for setting. The touch-pad in the control have maltfuntion. Only the pads which show: the roasting with conversion, cancel, 6, 9 are can show up when press on it and the other key pad are dead and no beep sounds either. What should I do? Is the control panel need the replacement or Control H1 Board? How to know or check about those elements are fails ? Thanks, Dinh |
Hi Dinh,
Open the control panel, remove the control panel ribbon from the control board and clean it, using an eraser. Plug it back and check if it'll work. If not then the control panel has to be replaced. - The part number for the control panel is AP3490588 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
I'm glad you were able to fix it.
__________________
| Display Modes | |
| How to use self cleaning on Tappan oven | miley1028 | Oven Repair (including Ranges and Cooktops) | 7 | Today 05:08 AM |
| After Cleaning Cycle - Oven does not work | bokeldol | Oven Repair (including Ranges and Cooktops) | 5 | 01-09-2008 07:59 PM |
| Oven failure F1 after self cleaning | Jeremy | Oven Repair (including Ranges and Cooktops) | 4 | 12-04-2007 04:34 PM |
| Oven will not work after self cleaning | Mike Seavey | Oven Repair (including Ranges and Cooktops) | 0 | 09-22-2007 07:44 PM |
| self-cleaning oven got so hot when cleaning that it melted the surrounding cabinet do | anne | Oven Repair (including Ranges and Cooktops) | 0 | 09-21-2007 07:30 PM |
