Register | FAQ's | New Posts | Today's Posts | Extras |
» Frigidaire F5 error when using burners |
![]() Model Number: PLEF398ccb Brand: Frigidaire Age: 5 - 10 years
![]() frigidaire PLEF398ccb electric range serial VF31904750 When my burners are turned on I get an F5 error in the little window where the power level shows up. It happens on both sides. Not at the same time, just when each side is turned on, that side shows the error. Looking around online, That error code indicates the need to replace the EOC. However, service documents tucked into the back of the unit in a plastic pouch don't say anything about the EOC and instead say the Power board or connections to it are the culprit. The oven and clock work just fine. It only happens using the burners Thanks, Alan Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Here is a wiring diagram
http://manuals.frigidaire.com/prodin.../316255121.pdf Here is a manual http://frigidaireservicetips.com/pdfs/477_5.pdf Not sure if it matches your exact model but it should be close or at least some sections should appy. I would do the following first. Connector Cleaning / Checking Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try.
__________________
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
frigidaire error code F10 - not listed in your error codes | Skully26 | Oven Repair (including Ranges and Cooktops) | 2 | 02-16-2010 04:29 AM |
Frigidaire error F-9 | fix it mom | Oven Repair (including Ranges and Cooktops) | 3 | 10-27-2009 06:40 PM |
frigidaire e70 error code | didcr1 | Washer Repair | 1 | 07-28-2009 06:07 PM |
frigidaire error | hemion20s | Oven Repair (including Ranges and Cooktops) | 3 | 04-11-2009 07:36 PM |
frigidaire error e10 | jeannesalisbury@gmail.com | Washer Repair | 1 | 03-23-2009 07:05 AM |
