| » maytag oven igniter to gas valve wiring |
Model Number: mgr4452bdq Brand: Maytag Age: 1 - 5 years
I need to know the proper wiring setup going to the oven igniter and safety valve. I have both of these parts new but the wiring was damaged somehow and I'm not sure how to wire them correctly. I hooked both of them up again and they both worked fine. Only problem is that the igniter and gas came on W/O setting the oven temp and stays on after it reaches temp. There is 120 volts continously from the red wire going into the igniter which in my opinion shouldn't be sending voltage unless I set the preheat on the control.
| Display Modes | |
| Oven fails to ignite: igniter, spark module or safety valve? | davidinnh | Oven Repair (including Ranges and Cooktops) | 0 | 01-05-2010 05:02 PM |
| Maytag oven not working (igniter or gas valve??) | mtpbr | Oven Repair (including Ranges and Cooktops) | 0 | 10-06-2009 03:33 PM |
| wiring for Kenmore gas range oven/broiler valve | manontheshore | Oven Repair (including Ranges and Cooktops) | 1 | 03-02-2009 04:55 PM |
| Maytag water inlet valve wiring | sks1982 | Refrigerator & Freezer Repair | 0 | 09-26-2008 08:59 AM |
| oven igniter - how to install / access maytag | wally | Oven Repair (including Ranges and Cooktops) | 0 | 11-21-2007 03:19 AM |
