The problem with my wall oven is that to get 350 degrees you have to set the temperature to 485 degrees. Both elements are working. Since yesterday I checked the temperature sensor and it reads 1.0K ohms at 75 degrees. Is this reading too low or is the ERC probably bad? I realize that the ERC is no longer made for this oven. Is it time for a new oven or will replacing the temperature sensor solve the problem? Thanks, Pappadon
Most likely the problem is a bad ERC. Looks like it is time for a new oven.
