Groups ready for retrieval: Registered
MY OVEN WILL NOT PREHEAT, IT TAKES I HOUR TO REACH 350 AND WHEN IT DOES IT DOES NOT FEEL LIKE 350,IT WORKED FINE TILL I SELF CLEANED IT AFTER THANKSGIVING NOW I AM HAVING A PROBLEM IT SEEMS LIKE THE BOTTOM ELEMENT IS NOT GETTING HOT, I DID MOVE THIS TO CLEAN UP THE ASH AFTER SELF CLEAN WAS DONE,i HAVE NO KNOWLEDGE OF OVENS. HELP is needed. JIll
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman If the element check's good, you would have to replace the clock control board. Tom ApplianceEducator.com
Originally Posted by: kayakcrzy If the element check's good, you would have to replace the clock control board. Tom ApplianceEducator.com Thanks for the help;the problem was the bake element replaced and working fine .Jill
