| » Whirlpool Oven Light Blinks On And Off |
Model Number: RF364PXMQ Brand: Whirlpool Age: 1 - 5 years
My Whirlpool Stove's Oven Light Blinks On And Off When The Stove Is On. If I Try To Loosen Or Tighten The Bulb Nothing Changes. If I Take The Bulb Out, The Stove Does Not Work. When The Light Is Blinking, All The Burners Work And The Oven Works.
Replacement parts for RF364PXMQ models | AppliancePartsPros.com Here is the tech sheet http://www.servicematters.com/docs/w...%209757347.pdf Has the unit always done this or is this something new? Sounds like you have a loose or bad connection somewhere and the control board is getting power through the light bulb. You did not say if the door switch or light switch must be on/off for this to happen so the problem may be one of these switches. Unplug the unit and check the connections at the terminal block. Especially the neutral wire to the control board. Make sure the ground strap is connected properly is it is a 3 wire hook up. Make sure that it is removed if it is a 4 wire hook up.
__________________
- Last edited by denman : 12-02-2009 at 06:09 AM. |
| Display Modes | |
| 'clean' light blinks | TJSMO | Dishwasher Repair | 12 | 06-06-2011 04:29 PM |
| light blinks and will not start | mcoldren | Dishwasher Repair | 1 | 07-12-2009 04:46 PM |
| Whirlpool Oven Timer Blinks XXXXXX | pureclassic | Oven Repair (including Ranges and Cooktops) | 3 | 05-12-2009 06:47 PM |
| washing light blinks | jh56ph55 | Dishwasher Repair | 1 | 12-01-2008 08:02 PM |
| Auto Clean light blinks | dwains | Oven Repair (including Ranges and Cooktops) | 0 | 05-03-2008 02:31 PM |
