Discuss
Oven doen't ignite
 in
I've been trying to find help to get my oven working again. I couldn't find a diagram anywhere
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven doen't ignite
  #1 (permalink)
Old 03-10-2008, 10:53 AM
Jewilson Jewilson is offline
Junior Member
Jewilson is on a distinguished road
Default Oven doen't ignite
Model Number: MGR4452BDW   Brand: Maytag   Age: 1 - 5 years
I've been trying to find help to get my oven working again. I couldn't find a diagram anywhere or repair information on replacing broken parts. I know that there is an ignitor for the oven but clueless as to what it look like or where to find it or if this is the problem. Everything else works just fine on the stove except heat fromthe oven. HELP!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-11-2008, 11:24 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Jewilson,
Remove the oven floor and the flame spreader to access the igniter (#14 on the gas controls break down diagram).
Unplug the igniter and check for 120V coming to the igniter while the oven control calls for heat.
If there is 120V - replace the igniter.
- The part number for the oven igniter is AP3455359
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-11-2008, 03:27 PM
curt60 curt60 is offline
Junior Member
curt60 is on a distinguished road
Default
I have the sme problem. my oven will not lite. I changed the wireing around using the top bureners wire into the oven igniter wire and put the oven wire into the top burner wiring both the top and the oven wireing get a spark. What do you think?
  #4 (permalink)
Old 03-11-2008, 03:35 PM
Junior Member
Default
My colic oven will not light. I did a little changing around wiring to see if I was getting current to my ignite rs. I changed my top burners wiring with my oven and i get a spark oven nob sparks the top burners and the top burner nob Sparks the oven. What do you think?
  #5 (permalink)
Old 03-11-2008, 04:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi curt60,
The first thing you have to do is put all wires back in their original position.
Then I need the complete model number of the unit and description of the original problem.
Post it as a new thread, please.
__________________
  #6 (permalink)
Old 03-11-2008, 04:33 PM
Junior Member
Default Oven will not ignite
I put the wireing back. The oven is a Cloric, Model RLN385 VW, serieal nomber 9402276778. I think it is a 1991. Oven will not light.
  #7 (permalink)
Old 03-11-2008, 04:59 PM
Junior Member
Default back in place
[quote=Gene;16738]Hi curt60,
Gene.[/quot
Model num. RLN3855
SERIL. 9402276778
Year I think 1991
  #8 (permalink)
Old 03-11-2008, 05:01 PM
Junior Member
Default Brand
I forgot to put in the brand. Coloric
Gene.[/quote]
  #9 (permalink)
Old 03-11-2008, 06:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Did you see the oven igniter sparking when you turned the oven thermostat "on"?
Can you hear or smell gas coming out of the pilot at this time?
__________________
  #10 (permalink)
Old 03-11-2008, 09:41 PM
Junior Member
Default
no spark but I do smell the gas when I turn on the oven dial I have a Caloric gas range model number. RLN385VW, serial number. P1142394N WI. I get no spark from the oven igniter. I do sell a little gas when I turn the nob to ignite the stove.
As I told you I changed the wiring around to see if I could get a spark using the top burner wiring and I get a spark that way. I also connected the wiring that usually goes to the oven to the top burner and that made the top igniters spark.
I put the wireing back. Now What?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven won't ignite ecramerjr Oven Repair (including Ranges and Cooktops) 1 02-25-2008 03:34 PM
Oven won't ignite under 350 holtzlou Oven Repair (including Ranges and Cooktops) 0 09-13-2007 06:39 AM
oven wont ignite mick100 Oven Repair (including Ranges and Cooktops) 3 08-27-2007 10:10 AM
Burners and oven will not ignite bren Oven Repair (including Ranges and Cooktops) 2 08-09-2007 01:15 PM
Oven does not ignite Dan Damiata Oven Repair (including Ranges and Cooktops) 0 08-09-2007 07:36 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
