Discuss
Whirlpool Double Wall Oven Won't Heat...
 in
Hello, Just bought a new (to me) house that came with a Whirlpool Accubake double wall oven. First thing we
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Double Wall Oven Won't Heat...
  #1 (permalink)
Old 12-01-2009, 07:28 AM
DaveinMD DaveinMD is offline
Junior Member
DaveinMD is on a distinguished road
Default Whirlpool Double Wall Oven Won't Heat...
Model Number: RBD306PDQ6   Brand: Whirlpool   Age: 5 - 10 years
Hello,
Just bought a new (to me) house that came with a Whirlpool Accubake double wall oven. First thing we did was run the self clean which caused the oven to overheat. I came straight here and started reading about what a common problem this is. I replaced the thermal fuse on the control panel and that got the display working. However, neither the top nor bottom oven will heat up. The fans run and the lights all work, but the ovens don't get hot.
The top oven display is on the left (I think) and we can set it to a desired temp and the fans run and the preheat timer counts down, but the temp never gets warm. We can't even get the temp to display on the right (bottom oven I assume).
My questions:
- Are there thermal fuses (part 37) for each oven? I thought in reading others' posts about this topic that there was only one.
- Is something else going on that I can't even set the temp on the lower oven? Doesn't seem like a thermal fuse replacement would cure that.
Thanks much for your help. Great forum and great website - I've fixed both a KitchenAid d/w and stove with parts/help from this site.
Dave
Related Models
Whirlpool RBD306PDQ6
Whirlpool RBD306PDQ7
Whirlpool RBD306PDQ8
Whirlpool RBD306PDQ9
Whirlpool RBD306PDT11
Whirlpool RBD306PDT12
Whirlpool RBD306PDT13
Whirlpool RBD306PDT14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDT15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDZ1
Whirlpool RBD306PDZ10
Whirlpool RBD306PDZ2
Whirlpool RBD306PDZ4
Whirlpool RBD306PDZ6
Whirlpool RBD306PDZ7
Whirlpool RBD306PDZ8
Whirlpool RBD306PDZ9
Whirlpool RBD307PDB1
Whirlpool RBD307PDB2
Whirlpool RBD307PDQ1
Whirlpool RBD307PDQ2
Whirlpool RBD307PDQ4
Maytag RBE170PA  Ref - Top Mount
Maytag RBE170PW  Ref - Top Mount
Maytag RBE170TA Ref - Top Mount
Maytag RBE170TM Ref - Top Mount
Maytag RBE170TV Ref - Top Mount
Maytag RBE170TW Ref - Top Mount
Maytag RBE17KA-0A  Ref - Top Mount
Maytag RBE17KN-0A  Ref - Top Mount
Maytag RBE193PA  Ref - Top Mount
Maytag RBE193PW  Ref - Top Mount
Maytag RBE193TA Ref - Top Mount
Maytag RBE193TM Ref - Top Mount
Maytag RBE193TV Ref - Top Mount
Maytag RBE193TW Ref - Top Mount
Maytag RBE19KA-3A  Ref - Top Mount
Maytag RBE19KN-3A  Ref - Top Mount
Maytag RBE19KY-3A  Ref - Top Mount
Maytag RBE214AFM Ref - Top Mount
Maytag RBE214AFV Ref - Top Mount
Maytag RBE214RFA  Ref - Top Mount
Maytag RBE214RFV  Ref - Top Mount
Maytag RBE214TFA Ref - Top Mount
Maytag RBE214TFM Ref - Top Mount
Maytag RBE214TFV Ref - Top Mount
Maytag RBE21KA-4AF  Ref - Top Mount
Maytag RBE21KA4AF  Ref - Top Mount
Maytag RBE21KN-4AF  Ref - Top Mount
Maytag RBE21KN4AF  Ref - Top Mount
Frigidaire RBF136CL Frg(v1) / Electric Cooktop
Frigidaire RBF139CE1 Frg(v1) / Cooktop
Frigidaire RBF139CE2 Frg(v1) / Cooktop
Amana RBG322T Mwave - Cntrtp / Stand Alone
Amana RBG322T1 Mwave - Cntrtp / Stand Alone
Amana RBG358P Mwave - Cntrtp / Stand Alone
Amana RBG622T Mwave - Cntrtp / Stand Alone
Amana RBG635T Mwave - Cntrtp / Stand Alone
Frigidaire RBGF119E1 BLACK Frg(v8) / Electric Cooktops and Control Box
Frigidaire RBGF119EL1 Frg(v7) / Electric Cooktops and Control Box
Frigidaire RBGF119EW1 Frg(v6) / Electric Cooktops and Control Box
Amana RBK22AA0 Range - S/i Std Gas
Amana RBK22AA093M Range - S/i Std Gas
Amana RBK22AA5 Range - S/i Std Gas
Amana RBK22AAL Range - S/c S/i Ddraft Gas
Amana RBK22AAW Range - S/c S/i Ddraft Gas
Amana RBK24AA Range - S/i Std Gas
Amana RBK24AA0 Range - S/i Std Gas
Amana RBK24AA093M Range - S/i Std Gas
Amana RBK24AA5 Range - S/i Std Gas
Amana RBK24AAL Range - S/c S/i Ddraft Gas
Amana RBK24AAW Range - S/c S/i Ddraft Gas
Amana RBK26AA Range - S/i Std Gas
Amana RBK26AA0 Range - S/i Std Gas
Amana RBK26AA093M Range - S/i Std Gas
Amana RBK26AA5 Range - S/i Std Gas
Amana RBK26AAL Range - S/c S/i Ddraft Gas
Amana RBK26AAW Range - S/c S/i Ddraft Gas
Amana RBK26CBL Range - S/c S/i Ddraft Gas
Amana RBK26CBW Range - S/c S/i Ddraft Gas
Amana RBK28FG Range - S/i Std Gas
Amana RBK28FG0 Range - S/i Std Gas
Amana RBK28FG5 Range - F/s Std Gas
Maytag RBK28FG5  Range - F/s Std Gas
Amana RBK28FGL Range - S/c S/i Ddraft Gas
Amana RBK28FGW Range - S/c S/i Ddraft Gas
Amana RBK29AA093M Range - S/i Std Gas
Amana RBK29AAL Range - S/c S/i Ddraft Gas
Amana RBK29AAW Range - S/c S/i Ddraft Gas
Amana RBL22AAL Range - S/c S/i Ddraft Gas
Amana RBL22AAW Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 12-02-2009, 07:24 AM
denman denman is offline
Senior Expert
APP Volunteer
denman has a spectacular aura about
Default
Replacement parts for WHIRLPOOL RBD306PDQ6 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/w...%204452022.pdfhttp://shared.whirlpoolcorp.com/asse...%204450568.pdf
And a service manual
https://secured.whirlpool.com/Servic...LE/8178007.pdf
Here also is the operators manual as it sounds like you do not have it
Since I do not see a fuse that will kill power to both ovens my gut says that you have lost the 240 volts. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without tripping the breaker.
Better yet measure it at the oven with a meter.
My questions:
Yes if the wiring diagram is correct but depends on the oven.
Yes this is worry some. As a fuse should not do this. Also if the sensor was gone I think you would get an error code. If the blower did not come on during self clean, it could be that the heat took out the board.
__________________
  #3 (permalink)
Old 12-02-2009, 07:45 AM
Junior Member
Default
Den Man - Thanks so much. I didn't have any sort of manuals for this oven as you suspected. Your trick worked - I flicked the breaker very slowly and now have power (in the display) and heat in the lower oven. I'll try a thermal fuse for the upper oven and will report back.
Thanks for taking the time to respond with so much info/links.
Dave
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool continuous clean double wall oven Liz Lewis Oven Repair (including Ranges and Cooktops) 0 11-17-2009 02:59 PM
Whirlpool Double Wall oven choldca Oven Repair (including Ranges and Cooktops) 6 10-13-2009 02:43 PM
Whirlpool double wall oven jledereich Oven Repair (including Ranges and Cooktops) 3 09-26-2009 04:10 PM
Whirlpool Double Wall Oven D.O.A JaredB Oven Repair (including Ranges and Cooktops) 1 02-07-2009 06:15 PM
Whirlpool double wall oven Diana Oven Repair (including Ranges and Cooktops) 0 02-26-2008 09:28 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
