kenneth230
#1 Posted : Monday, November 30, 2009 10:46:26 AM(UTC)
kenneth230
Control panel lights not working after self clean.
Does not show temp, but the clock keeps time, but fades in & out.
Oven comes on at 350 but controls do not show temp.
Is the problem circuit board or control board?
This oven has hardly been used.
Any help appreciated . Ken
#2 Posted : Monday, November 30, 2009 6:09:56 PM(UTC)
Ken,
Sounds like the problem is a bad control board.
- The control board (microcomputer) Part number: AP3873768
kenneth230
#3 Posted : Tuesday, December 1, 2009 3:13:25 AM(UTC)
kenneth230
Gene, Will it be a big problem for a semi-skilled handyman to change this control board? Any special tools needed? Ken.
#4 Posted : Tuesday, December 1, 2009 12:22:05 PM(UTC)
Ken,
I do not think this job is going to be too difficult and you do not need any special tools.
The first step is to remove the oven side trims. Open the lower oven door and remove the screw from each side trim. Remove the side trim by pulling the bottom out approximately 2", and slide the top down to free it from the control panel.
I'm not certain on how to remove the control panel on this particular model. It looks a little bit differ with most others, but I believe it's not going to be very complicated. If it would, post some pictures.
whirlpool range GS395LEG (Oven Repair (including Ranges and Cooktops))
by Guest 3/18/2024 12:17:23 PM(UTC)
whirlpool range Model xfg374lvs (Oven Repair (including Ranges and Cooktops))
by Guest 1/21/2023 11:09:59 AM(UTC)
I have a whirlpool range Model #WFG505M0BS3 (Dishwasher Repair)
by Kbarbie 7/2/2022 10:13:00 AM(UTC)
Whirlpool range GR399LXGT2 (Oven Repair (including Ranges and Cooktops))
by Guest 1/29/2022 7:27:05 AM(UTC)
Hidden bake element whirlpool range (Oven Repair (including Ranges and Cooktops))
by Guest 8/12/2021 10:05:04 AM(UTC)
Whirlpool Range issue (Oven Repair (including Ranges and Cooktops))
by Guest 7/25/2021 9:31:56 AM(UTC)
Whirlpool range oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by Guest 5/10/2021 12:58:16 PM(UTC)
Whirlpool range touchpad won't display (Oven Repair (including Ranges and Cooktops))
by kleindon 10/6/2017 7:15:22 PM(UTC)
No bake, no broil on Whirlpool range. Help! (Oven Repair (including Ranges and Cooktops))
by JamesTheScot 8/13/2015 8:31:22 PM(UTC)
Whirlpool range supply voltage problems (Oven Repair (including Ranges and Cooktops))
by TheSunny1 11/11/2014 5:56:36 PM(UTC)
Whirlpool range cooktop won't work code 79 (Oven Repair (including Ranges and Cooktops))
by jdgough624 11/9/2014 10:06:55 AM(UTC)
Whirlpool range no digital display or oven working (Oven Repair (including Ranges and Cooktops))
by bdbwtie 4/5/2014 6:57:10 AM(UTC)
Whirlpool range door won't open. (Oven Repair (including Ranges and Cooktops))
by Electechab 1/27/2014 11:07:17 AM(UTC)
whirlpool range top not working (Oven Repair (including Ranges and Cooktops))
by bck621 1/6/2014 7:54:41 AM(UTC)
Whirlpool range (Oven Repair (including Ranges and Cooktops))
by AlanO 10/2/2013 2:54:13 PM(UTC)
